TLR 22SCT Thread (Check First Page for FAQ & INFO)
#2956
Well the SCT is getting pretty dailed in, and with the mid-motor set up at that. Does anyone know of an editable set-up sheet I could get online that would allow me to ave a copy so I post it here. Its doing so well I am thinking of converting the buggy to mid motor
http://www.tlracing.com/Products/Def...024#prodSetups
#2958
Ran my truck for the first time last night and im pleased .... truck handles very well other then few things i saw it doing 1) going into turns and coming out the truck rolls a ton and i lose traction .. i would assume the sway bars will fix this .. but i diid try stiffer spring i went from stock yellow to pink and raised the ride height alittle . im running travis brock set up on the tlr web site , im almost sure 27.5 all the way around is too light for tight indoor track with med to high grip.. 2) it jumps good but front end flys alittle high .. i know on my xxx sct i had to add about 3/4 oz weight to the front do i need to do that with this one too ? .... if someone else can tell me something to try i am open ears because i know this trk will be dialed when i get it to work 100 % the way i want it to thanks all in advance Will G
#2959
Here is the link to the editable setup sheet off the TLR Racing site:
#2963
I currently drive a FT SC10 and after a lot of trial and error its dialed in. With that said, Im very tempted to switch over to the 22sct. I already own and race the 22 buggy and scte. My question to you guys is... how does the 22 handle around corners? What I like about the SC10 is its ability to turn on a dime but can be very twitchy.
I guess what im looking for are reasons to dump my SC10 for the 22.
Thanks in advance.
Thanks in advance.
#2964
Thanks in advance.
Thanks in advance.
#2966
In the manual, page 12 has the shim requirements. Page 11 has the number of teeth you need for your servo horns.
All kits came with a manual. The manual is also available in online/electric form here:
http://www.tlracing.com/ProdInfo/Fil...024_Manual.pdf
One thing I really like about the online manual is that you can search it. IE: you can search for 'servo' or 'shim' and go right to what you need.
Ideally this thread is for all things NOT covered in the manual.
#2967
Agreed. We have a few at our track and they have just as much steering as my Kyosho with few, if any modifications
#2968
Thanks in advance.
Thanks in advance.
No seriously I sold my SC10RS roller (Few FT Upgrades) and have just bought the 22SCT kit.
I loved my 22 Buggy so much I figured having both cars on the same platform should make tuning and spare parts stocking alot easier.
#2970
Still a very nice purchase and would recomend it to anyone
