TLR 22SCT Thread (Check First Page for FAQ & INFO)
#1921
Taxxis make 3mm rod end too for the guys that want to do that with the captured rod ends and then tap it 4mm and good to go.
#1922
so yea i know i asked this a couple of pages back but no reply. does anyone know if the wheels from an AE kit will fit ? are they the same offset ? im thinking of making the jump and i have alot of tires that are on AE wheels.
#1923
Scott how about a list of bodys that fit and dont fit.
Jconcepts raptor wont fit
Jconcepts Hi Flo wont fit
Parma speed flow wont fit
Proline chevy high flow wont fit
Proline toyota high flow will fit
Losi scte will fit
Losi scte will fit
#1925
Thanks for the comment on this Scott. I started racing back in the day in Ohio when Todd Hodge was still racing with Scooter's Motor Works. I also have a 8 year old boy and 10 year old boy racing. I had to come up with a solution for this because it is no fun watching your son come off the track because his car is broke in a race. Again thanks for all your help on this page and I would like to say "Hats off to the guys at Losi!" This was the best build out of all the 22 line up. Main reason for this is constant improvement and listening to the racers out there. I would have to say this is why Losi is on top!
#1926
#1932
Tie rod pop-off issue
Regarding the tie rods poping off, keep caster in mind. I went to 20 degrees overall caster in the front for running on carpet which added a crazy amount of bump steer as well as tie rods poping off with only landing hard off of jumps, let alone crashing. I moved the bump steer washer (between spindle and steering knuckle) from the top to the bottom and put short 4-40 ball studs and cups in the steering knuckle, part #LOSA6029. No more bump steer and no more tie rods poping off even with hard hits.
#1933
#1934
