SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 07-19-2012 | 01:19 PM
  #526
gamedog1966's Avatar
Originally Posted by Tijuana_Taxi
Associated makes a rear kit that bolts right on.
http://www.amainhobbies.com/product_...-Bar-Kit-B4-T4
Do they wrk for front and rear?
gamedog1966 is offline
Old 07-19-2012 | 01:37 PM
  #527
It's a direct bolt-on for the rear, if you want to run one on the front you will need to adapt it like Nismomike did in this thread.
http://www.rcshortcourse.com/forum/t...tml#post222188
Tijuana_Taxi is offline
Old 07-19-2012 | 05:05 PM
  #528
Default Gear diff rebuild probs!!
I just put together new gear diff and first time out it started ratcheting about four laps in. I followed I put all shims included in rebuild kit and it is only hitting in outside of spiders. Anybody have this problem before???
BADMOFO is offline
Old 07-19-2012 | 05:09 PM
  #529
Cloaked's Avatar
As far as I knew the new Gear Diffs didnt have this problem.
Cloaked is offline
Old 07-19-2012 | 05:17 PM
  #530
This is second one this year! Although the first had about 9 million laps on it before it went!!! I think I need to take shims out of spider gears and hopefully that will let them drop in further but not to far !!! New housing and new rebuild kit wanted to start fresh and it's been a pita!!!
BADMOFO is offline
Old 07-19-2012 | 05:34 PM
  #531
How different do your truck feel and perform with the gear diff instead of the ball?
Old 07-19-2012 | 06:44 PM
  #532
19_mustang_96's Avatar
I built one that is very similiar. Works get on carpet, had mixed results on dirt.
19_mustang_96 is offline
Old 07-19-2012 | 10:01 PM
  #533
I foresee A LOT of FT SC10's going up for sale soon. I'm keeping mine for sure but may pick up the new flavor of the week anyhow.
Kuya_Kimo is offline
Old 07-19-2012 | 10:14 PM
  #534
Cloaked's Avatar
Good chance to get some cheap rollers.
Supply and demand will be great, too much supply and not enough demand!
Cloaked is offline
Old 07-19-2012 | 10:41 PM
  #535
monty c's Avatar
From: Dont get any more northwest than me..........
so i hear of lots of associated guys lowering the inner rear ball stud on thier buggy and truck, is anyone doing this on the SC10? what is the effect? im currently running the Maifield setup and love it, what will change by shaving down the rear camber block and lowering the ballstud?? just curious....thanks ahead of time
monty c is offline
Old 07-19-2012 | 11:55 PM
  #536
i have shaved the u braces on all of my ae vehicles and it do help in locking the back ends down with the c hubs also, i run them with the u brace shaved and no washer under the rear ballstud on all my vehicles also
Old 07-20-2012 | 09:27 PM
  #537
Riv2SC10's Avatar
From: In the Greater Ladysmith, WI metropolitan area
I took it a step further and recessed the ballstud mounting surfaces 1/32" below flush (about 1 washer's worth). It raised the roll center (a topic which gets complicated pretty fast) and increases the camber gain with suspension compression (i.e. when the truck leans in the corners). For me this has resulted in higher cornering speeds on the medium to low grip track I usually race at.
Riv2SC10 is offline
Old 07-20-2012 | 09:31 PM
  #538
Riv2SC10's Avatar
I'm apparently out of the loop, which is typical. Why do you foresee this? 4wd taking over? I live in the northwoods of Wisconsin, trends are typically delayed up here.
Riv2SC10 is offline
Old 07-20-2012 | 09:34 PM
  #539
elex300's Avatar
Im keeping mine but you cant deny the showing the new flavor had today at the Shoot Out.
elex300 is offline
Old 07-20-2012 | 11:21 PM
  #540
care to elaborate with a bit more detail?
Micah123 is offline
