SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 05-01-2013 | 05:33 AM
  #3571
Originally Posted by Wildcat1971
the reduce chassis slap on landings. otherwise imo, no they are not needed.
How would the big bores reduce chassis slap? (curious)
shagnat is offline
Old 05-01-2013 | 06:30 AM
  #3572
Suspended
They are biggers shocks so they have more shock resistance, which mean that they will stop the truck from bottoming out when landing off a jump wear the stock ones seem to do it a lot if u don't land jus right
theblitzkidd is offline
Old 05-01-2013 | 08:50 AM
  #3573
mblgjr's Avatar
Thanks for the reply. I'm a rank novice driver. Would I notice any difference? Would either be beneficial over the other?
It's not going to make or break you.
I only ran 25's on slower, smoother tracks.
Rough/outdoor or running +3mm offset wheels, the 30's are fine.
Work on your overall driving first before worrying about this.
mblgjr is offline
Old 05-01-2013 | 09:20 AM
  #3574
Loving my SC10's, but having issues with durability. Every race meet I spend so much time at the wrench bench trying to keep my sons and my truck in order. They're not thrashed, we treat them well, but there always seems to be something.
My solution you ask? I'm starting to carry enough spares that I could start my own LHS. :P
Can't imagine ditching the SC10 any time soon. If not for the amount of money I've put into them, the simple fact I do _LOVE_ how they drive. I do think I'll convert one to SCB though, seeing as how SCTs and SCBs run together as one class at my local track.
Chamelion is offline
Old 05-02-2013 | 06:52 PM
  #3575
20 SMOKE's Avatar
any of you still using the avid springs
20 SMOKE is offline
Old 05-02-2013 | 07:47 PM
  #3576
I run them front and back. One of my better upgrades..
astarback is offline
Old 05-02-2013 | 07:51 PM
  #3577
Suspended
The sc10 is fragile, but if u are not concerned about weight then I suggest the RPM products for u, it will surprisingly make the sc10 almost indestructible I went all rpm with my t4 and I mean that thing takes a whooping haha, I did end up breaking the front bumper, but rpm is covered by the warrantee so I sent it in for a new one
Old 05-03-2013 | 10:57 AM
  #3578
What kind of set ups do you guys prefer outdoors. I like the truck loose so I run 30wt shock oil with blue Team Assoc rear springs and silver fronts but I have not run an outdoor track yet. Clay track and bumpy with good sized doubles. Im just trying to eliminate going in the complete wrong direction so just looking for ideas.
Dvndad is offline
Old 05-03-2013 | 12:24 PM
  #3579
Suspended
I run 1 bumpy outdoor with med jumps and I have silver springs in front, and green in the rear, and 37.5 all around with 3 hole pistons, and I do ok with that. And on the indoor I run the same setup on the indoor track with high jumps and tight corners,but I have to put in a 1/2 inch spacer on the springs.
Old 05-03-2013 | 12:46 PM
  #3580
What spacers do you run for outdoors? I was thinking about running the same set up and just bumping the fronts to 40wt
Dvndad is offline
Old 05-03-2013 | 12:48 PM
  #3581
We have a 10' section of woops so I run it loose and glide over them.
Dvndad is offline
Old 05-04-2013 | 07:38 PM
  #3582
aniedert36's Avatar
Default STRC Rear Chassis Brace / Bulkhead
Have any of you guys tried this brace? I put this on from beginning (haven't ran with the plastic brace ever). The truck is so incredibly loose on power on the exit of the turns.
It's sooo loose it almost spins out in the straights and I can barely clear any of the jumps. I can't ever seem to get the power down to the track. Do you think the aluminum piece is too stiff causing the rear not to work?
I maxed out on most adjustments to try to get some grip in the rear. What are your thoughts?
aniedert36 is offline
Old 05-05-2013 | 12:23 AM
  #3583
LOSI123's Avatar
Has any one fit a hobbywing sct pro esc to the sc10 with out mods, does it fit?
LOSI123 is offline
Old 05-05-2013 | 09:47 AM
  #3584
Suspended
The brace isnt whats causing the truck to act like that, its prolly your susp setup or the tires!!
Old 05-05-2013 | 11:35 AM
  #3585
Acill's Avatar
Great springs, I run them on my B4.x T4.x and my SC10.
Acill is offline
