my losi ten t brushless conversion project
#76
will a mamba monster esc with a 2200kv mamba monster motor fit in my losi ten t?
#78
my novak hv 6.5 motor came in the mail today now i just gotta order a few small parts then my esc will be here early next week. i put the losi ten scte front bumper on my ten t also.
#79
so sad about this thread, figured there would be some ending with pictures after all the to-ing and fro-ing about the motor and batteries.
run 5s on the mmm/2200 and you'll be within their "sweet spot rpms" and you'll have no overheating... but then again...it will be under control and thats no fun.
#80
It has a BCE E-Line (Electric specific) chassis, the motor mount is an RC-Monster Ten-T conversion mount, battery tray
is an SCTE part, ESC is Mamba Max Pro, motor is a Novak HV6.5 with the 14MM tuning rotor, and runs on 3S LiPo.
Hardened diff outdrives all around, King Heads CVD pin keeper on rear center drive with TeknoRC Front center drive &
King Heads dual bearing forward center diff mount.
Designed for racing so I used a conservative motor setup.
#82
8ight-T parts on a Ten-T?
Well, 8ight Buggy (not truggy) shocks work well.
As far as all the rest, I suppose you could do it it you machined yourself a custom chassis. But what would be the point? Then you would have an 8ight-T with a short wheelbase instead of a Ten-T. All the stuff that makes a Ten-T be a Ten-T would be gone.
#84
My motor is 36MM diameter. The Castle 2200 is 42MM diameter. RC-Monster motor mount (what I have on my Ten-T-E) was designed to fit the 42MM motors. So does the Elite mount. You can fit a 42MM motor using the Losi mount if you modify the plastic piece that goes under the diff mounts.
#86
