Tekno RC EB48 Thread
Hey picked up a used Eb I think intead of tekin Im going to go Hobbywing. I cant find any pictures of a 150a esc in the buggy should I just go with a sctpro? is the 1800kv motor the one to get? pictures would be greaT If the 150amp does fit Id love to see how tight it is
Ya the 150a is over kill and tight to get into this buggy. If you did go this way you should mod the case so you can move your wires. The SCTPRO is 120a and more then you need. That's what I run in my buggy along with the Tekin 1900. My sctpro is just as smooth and my rx8. If I didn't tell you, you wouldn't know. I don't feel like I've ever put it to the test on limits. It has always come off the track cool
I run a 150a in both of mine also I posted some picks of them last yr.
Very clean install . Similar to the one above but I modded the esc case instead of mud guard works great ill try to post a pic
I used a hot iron and melted a channel for the reciever wire to run down case and for the sensor wire I just removed the plastic below the connector and ran wire under the esc mounting plate works awesome
Ill be in flowood mississippi for the Jamie Rogers memorial race this weekend.
Showing up late with no practice so it should be one of thoes challenging weekends. I know we will have quite a few eb's out there.
Do you want your rear end to rotate faster or break loose and drift easier? If the former would go to 3k in the rear
2Likes
