Tekno RC EB48 Thread >
Like Tree2Likes
Old 04-01-2014 | 08:07 AM
  #11926
vwduud's Avatar
Originally Posted by HollywoodRC
I installed the BCE chassis and it's a game changer. The buggy is a lot more stable in the rough sections and the flex makes it stick to the track. Great job BCE, i highly recommend this upgrade!
Did you make any changes to your setup after changing the chassis?
vwduud is offline
Old 04-01-2014 | 10:09 AM
  #11927
GaMudDawg's Avatar
I was surprised how well my tekno eb48 held up at psycho nitro blast. I put the .1 version diff case in and added our home made brace and didn't have any problems out of the buggy itself. I hit the chassis on the big vertical double and hurt the esc. Other than that the buggy survived pnb with my poor driving.
GaMudDawg is offline
Old 04-01-2014 | 10:33 AM
  #11928
Mizchief's Avatar
Originally Posted by cpt_RedBeard
Just as a precautionary measure I would loop the motor wires around to the other side of the solder tabs leaving some wire slack. Especially when running the thinner more flexible BCE chassis. The EB48 flexes quite a bit and you really don't want anything pulling or pushing on the solder poles on a RX8.
+1 I did my ESC that way the first time in my SCT410 and it eventually broke the bell off my pro4hd due to the flex.
Mizchief is offline
Old 04-01-2014 | 10:41 AM
  #11929
Mizchief's Avatar
+1 I ran front and rear braces and did break one .2 rear gear box my last round of practice and also killed an ESC, then broke a rear CF tower on my SCT410.
I didn't really make any setup changes from my normal outdoor setup and the buggy handled great all weekend. It would hold the line as hard as I was able to push it within my skill set.
Mizchief is offline
Old 04-01-2014 | 12:56 PM
  #11930
Torian4000's Avatar
I'm ready!
Torian4000 is offline
Old 04-01-2014 | 02:10 PM
  #11931
FastPete's Avatar
Originally Posted by Torian4000
I'm ready!
Love the paint!
FastPete is offline
Old 04-02-2014 | 12:29 PM
  #11932
justpoet's Avatar
Diggin the paint here too. Nice job!
justpoet is offline
Old 04-02-2014 | 12:34 PM
  #11933
Hoese37's Avatar
GAuging interest in a 5mm rear carbon tower for the SCT/EB/NB. Who would all be interested?
Hoese37 is offline
Old 04-02-2014 | 01:39 PM
  #11934
justpoet's Avatar
What is the expected weight compared to stock and compared to tekno cf towers?
justpoet is offline
Old 04-02-2014 | 04:18 PM
  #11935
jlfx car audio's Avatar
So are the .2 rear diff cases failing without cause ? Or are they breaking cause of a wreck, stress? Whats breaking/failing ?
I have 2 of the first gen EBs and was going to change them out..
jlfx car audio is offline
  #11936
Old 04-02-2014 | 04:21 PM
  #11937
jhautz's Avatar
Dont know the weights of the Tekno CF tower but if its 4mm and the 5mm is 25% thicker at 5mm then it would be 25% heavier. Weigh your CF tekno tower and multiply by 1.25. That should be a reasonable estimate.
jhautz is offline
Old 04-02-2014 | 04:42 PM
  #11938
GaMudDawg's Avatar
Tekno said that there was a bad batch of the .2 cases that was injected/molded at a lower temperature than normal thus causing them to fail at the top ears of the case. I ran the .1 cases at psycho nitro blast because it seemed people haven't had as many problems with them compared to the .2 diff case. I'm not sure if the .1 case is stronger or not. I do know the two guys I pitted with both broke .2 cases in pro e buggy class during psycho nitro blast. They both where able to finish the race because of the metal brace they run.
Old 04-03-2014 | 03:33 AM
  #11939
Hi,
I'm about to pull the trigger on a new EB48.2.
Can you list me what spare parts I need to keep racing for a while without worring too much about crashes?
thanks
Xan83 is offline
Old 04-03-2014 | 08:46 AM
  #11940
cpt_RedBeard's Avatar
Originally Posted by Xan83
Hi,
thanks
Not in any order of importance:
TKR5016B – Rear Gearbox
TKR5036XT – Suspension Arms front
TKR5030XT – Suspension Arms rear
TKR6017 – Shock Shafts (rear)
TKR6004 – Shock Shafts (front)
TKR6005 – Shock Rod Ends
TKR5034 – Hinge Pins (outer, rear)
TKR5028 – Shock Tower
TKR5026 – Wing Mount
TKR5021 – Hinge Pin Inserts
TKR5020 – Hinge Pins (x2)
TKR1333 – M3x40mm Flat Head Screws
TKR5237K – Spur Gear
cpt_RedBeard is offline
