Tekno RC EB48 Thread >
Like Tree2Likes
Old 02-05-2014 | 07:32 PM
  #11326
LAZNICK RC's Avatar
Originally Posted by S.TRIPP77
For the up an down movement in the spindles u might to able to take a file(flat /bastard) and file a little on the bushing. That will let u tight up on the screws and take out the extra play.
The play in the front arms I used the kyosho arm washer that come with the front or rear arms. And I shim the rear side of my front arms, I didn't have to but I did.
But the axle play needs the shim cause when u turn lock to lock the axle will just slightly rub the drive shafts when they float in but it doesn't rub when it floats out ward.
Thanks guys for info
LAZNICK RC is offline
Old 02-05-2014 | 08:17 PM
  #11327
boudin4evr's Avatar
anybody know the length of the rear turnbuckles?
boudin4evr is offline
Old 02-05-2014 | 08:39 PM
  #11328
The TKR5050 IS 58MM LONG AND SO IS THE FRONT CAMBER LINK IS 58MM. The answer is on the first page sir.
S.TRIPP77 is offline
Old 02-06-2014 | 06:29 AM
  #11329
spdrac430's Avatar
will the Team Trinity "D8" motor fit in the EB48 with a sctpro Hobby wing esc
spdrac430 is offline
Old 02-06-2014 | 07:08 AM
  #11330
UK.hardcore's Avatar
Should fit just fine, its smaller then a T8 truggy motor.
UK.hardcore is offline
Old 02-06-2014 | 07:24 AM
  #11331
Bernard_Jr's Avatar
I have the esc and the on/off switch both mounted on the esc plate. I can take a better photo when I get home if you want but they fit fine together.
Bernard_Jr is offline
Old 02-06-2014 | 01:01 PM
  #11332
Bortzilla's Avatar
I see that the Tekno truggy shock springs come with a silver coating on them. Does anyone have the inside scoop on if Tekno is going to move to a silver coating on the buggy/sct springs? The black coating seems to come off of the current ones kind of easily. Thanks!
Bortzilla is offline
Old 02-06-2014 | 01:09 PM
  #11333
ZERTA RACING's Avatar
Hello Everyone,
As some of you may have encountered there was a batch of TKR5016B that were breaking where the tower mounted to the bulkhead.
We have just received a new batch. For anyone that has experienced a breakage of TKR5016B and still have the broken part, please follow the procedure below to receive a replacement.
You must send the warranty eligible part(s) back to us for replacement. Here is a list of what to include with your shipment:
The part(s) in question.
A note with your return address, telephone number, and email address.
Optional – any information about your setup (motor, voltage, wheels, tires, etc.). The info you provide will help us to make our products better.
Please send the above items to:
Tekno RC
ATTN: WARRANTY / REPAIR
10755 Scripps Poway Pkwy #598
San Diego CA 92131
You can speed the process along by filling out this form before sending in your parts:
http://www.teknorc.com/tekno5/wp-con...erSaveable.pdf
Once we receive your part along with the information above we will issue a coupon code via email good for 100% off of a replacement. Add the TKR5016B to your cart, go to checkout and enter the coupon code. Your discount should appear. Proceed through checkout normally and we’ll get the order processed ASAP.
Thanks for choosing our products!
Thomas,
Tekno RC Customer Support
ZERTA RACING is offline
Old 02-06-2014 | 01:15 PM
  #11334
At this time we have no plans to change how the buggy and SCT410 springs are coated. I makes it much easier for those with truggies and buggys to tell which spring are for buggy or truggy. If they were all sliver then you would have to measure the length and wire thickness to determine if it was a truggy spring or a EB/NB/SCT spring, It would just get confusing.
-Thomas
Old 02-06-2014 | 01:21 PM
  #11335
Originally Posted by ZERTA RACING
Hello Everyone,
Tekno RC
San Diego CA 92131
Thomas,
While I have now experanced this type of break with mine, I have experanced the screw portion breaking for the rear chassis brace. Will this type be covered as well?
micrors4guy is offline
Old 02-06-2014 | 02:37 PM
  #11336
Please send an email with pictures of the broken part with your contact information to [email protected] for further assistance.
-Thomas
Old 02-06-2014 | 03:40 PM
  #11337
FastPete's Avatar
Hello Everyone,
Tekno RC
San Diego CA 92131
Thomas,
Nice Thomas-Tekno!
FastPete is offline
Old 02-06-2014 | 05:06 PM
  #11338
BLbound's Avatar
Awesome, thanks Tekno!
BLbound is offline
Old 02-06-2014 | 09:47 PM
  #11339
Quick questions all,
For the shocks, I am putting the bottom eyelet on each of my front shock shafts, but one eyelet bottoms out before the other leaving a difference of about 2 mm in overall shaft length, what is the proper length of the shock shaft with the eyelet seated and no piston?
Next, when the shock shaft is finished, the nut on top sticks up, should this nut touch the bladder at all?
Final, in order to potentially limit upward travel so the nut don't hit the bladder do you use limiters on the outside of the shock like the sct410?
cryofix is offline
Old 02-06-2014 | 10:15 PM
  #11340
Default DURANGO ALUM PINIONS
SOMEONE SAID THEY WAS USING THE TEAM DURANGO ALUM PINION, I was wanting to know how it was wearing???
