Tekno RC EB48 Thread >
Like Tree2Likes
Old 01-04-2014 | 07:16 PM
  #10546
Originally Posted by Dont Hack Me
[IMG][/IMG]
I had asked about this a couple of posts ago. Is this the way the motor mounts are coming now, not breaking out the bottom of the slot for strength. I'm hoping that wasn't a one off, It would be a lot stronger, my motor has a little bit of a lean to it from my mount
That's the revised motor mount. It's not a one off.
Mark
munrath is offline
Old 01-04-2014 | 07:18 PM
  #10547
Originally Posted by FastPete
Wrong quote, im talking swaybars.
LOL
Mark
munrath is offline
Old 01-04-2014 | 09:29 PM
  #10548
Rockthecatbox21's Avatar
Mark
Nice. I looked back at some of my .1 kit pictures and the motor mount is indeed different. Much improved and i take back what i said about it needing to be beefier. Tekno amazes me how much little improvements they make and my own ignorance that causes me to not notice them. Thanks very much tekno.
Sorry for the complaints.
p.s. That et48 tempts me so.
Rockthecatbox21 is offline
Old 01-04-2014 | 10:11 PM
  #10549
jhautz's Avatar
How do you get the bottom screw in that new motor mount?
jhautz is offline
Old 01-04-2014 | 10:16 PM
  #10550
FastPete's Avatar
Through the hole in the side tray. Its easy.
FastPete is offline
Old 01-04-2014 | 10:28 PM
  #10551
LAZNICK RC's Avatar
Mark
Hi when did this motor mount come out ?
I have the eb48.2 and does not look like yours?
Is this another running improvement by tekno for et48 and for eb48.2
LAZNICK RC is offline
Old 01-04-2014 | 10:29 PM
  #10552
jhautz's Avatar
Did they revise the side tray too? The hole in mine is no where big enough to fit the head of the screw through.
jhautz is offline
Old 01-04-2014 | 10:58 PM
  #10553
Is another improvement by tekno?
my eb48.2 came with the new mount. i purchased it on black friday so i don't know when it may have been updated.
When i was building, there was an addenum sheet showing the new mount and the larger hole in the plastic side guard.
Old 01-04-2014 | 11:58 PM
  #10554
LAZNICK RC's Avatar
Yes as it would I have checked et48 manual it's the standard motor mount ,beefier for larger truggy motors
Flows on to eb48.2 with revised esc tray aswell
Good job tekno now for the split center diff / with new motor mount
Does the light weight motor mount get the same treatment!
Will you be able to still buy the previous mounts respectively as the new one / s may be slightly heavier !
Old 01-05-2014 | 01:48 AM
  #10555
GrimReminder's Avatar
You said it brother...I could really use a split center diff mount. Im always changing stuff around a this would cut out down time for sure. Ive heard thru the grapevine that elite rc has a motor mount and split diff in the works, but im considering this a rumor for now.
As of right now a split center diff is all I would change on the .2, besides that this kit is on point.
GrimReminder is offline
Old 01-05-2014 | 02:56 AM
  #10556
LAZNICK RC's Avatar
Old 01-05-2014 | 03:27 AM
  #10557
Genebaby's Avatar
I have a set of the 16mm Fioroni pistons on the way now.
I was going to get some of the non-vented shock caps when they come into stock at Amain.
Is that advisable with these pistons?
Genebaby is offline
Old 01-05-2014 | 05:28 AM
  #10558
FastPete's Avatar
Must have, its no problem
FastPete is offline
Old 01-05-2014 | 06:31 AM
  #10559
8ight-e's Avatar
Just a tip.. take the stock pistons, use your soldering iron and a zip tie to fill and then seal up two holes on each piston (opposite each other). This is the best/cheapest way to get the pack up.
I'm not sure where this fad came from w/ the emulsion shocks, but I still will stick w/ the bladders and being able to set my rebound; typically I find around 20% front and 10% rear is best. But that is a to each his own.
8ight-e is offline
Old 01-05-2014 | 06:37 AM
  #10560
I picked up a .2 in November, still running the old mount and side tray. As soon as i can make sure i can order one, where I don't get the old stock, better believe im getting one. That's been the only thing that i never cared for, it bends a little then makes your mesh scream. Since you can't get them to be Parallel anymore. Didn't slow my buggy down one little bit tho. If we are throwing out "please make me" I would love to see split diff, CNC at the wheels, bearing instead of bushings for the steering. Now i know this is over kill BUT i would pay for it. Knowing that the bushing are not gonna wobble out the holes up front...More so that would look awesome!
Dont Hack Me is offline
