Tekno RC EB48 Thread >
Like Tree2Likes
Old 06-26-2013 | 01:37 PM
  #7531
Rockthecatbox21's Avatar
Somebody requested i post pics of my xerun 150 amp & 2250Kv setup in my eb48. It was a tight fit, but it hasn't had any problems in the past 4 months i've raced this buggy.
Rockthecatbox21 is offline
Old 06-26-2013 | 03:35 PM
  #7532
Suspended
It was probably me asking for pics as I was having fitment issues with my sp sav2. I also have some hw escs like yours but I ended up putting some clearance in the mud guard for the esc wires. Thanks for posting though.
MattP is offline
Old 06-26-2013 | 03:37 PM
  #7533
Suspended
What size pinion do most of you that use 1900kv motors end up using? I'm going to start with a 16t and go from there and adjust accordingly.
MattP is offline
Old 06-26-2013 | 03:42 PM
  #7534
I think you will find the 16 too small, I usually run 17 or 18t.
jpas is offline
Old 06-26-2013 | 03:45 PM
  #7535
I used an 18 tooth when i was using the 1900 in my buggy.
It was actually another user who pm'd me about pics of the setup. Figured i'd post it here just so people can search and find it. I did do a little dremeling to give the esc wires some clearance, and even cut out a little spot in the body to keep the wires from rubbing.
Old 06-26-2013 | 04:04 PM
  #7536
Suspended
Ok sounds like I need to go up on pinion size for sure.
MattP is offline
Old 06-26-2013 | 05:59 PM
  #7537
justpoet's Avatar
I started with a 17t. On our outdoor track it wasn't quite enough down the straight, so I went to 18t without issue. I've contemplated trying a 19t a couple times, but haven't done it yet. If you have a very large track with a long straight, expect to try the 19t. If you have a small technical track or not much of a straight, expect to be in the 16t or 17t range with the 1900.
justpoet is offline
Old 06-26-2013 | 06:03 PM
  #7538
Originally Posted by nv529
Does anyone have the JC body yet?
here is mine. Fits like a glove
rythby is offline
Old 06-26-2013 | 06:11 PM
  #7539
Originally Posted by protc3
I know. I use thicker oil to tone the car down a bit with the softer springs. I bounce between 40 and 45 front and stay with 35 rear. those oils with the soft spring combo works great. The lighter oil wasnt good. Car was darty.
You don't have off power cornering issues with the thicker weight oil? I've been playing with some oil setups myself to see what I can find that works the best for my local track.
RokleM is offline
Old 06-26-2013 | 06:15 PM
  #7540
protc3's Avatar
With heavy springs i do but not with lighter springs. I actually have a ton of steering every part of the corner but its not violent steering. Very controlable.
protc3 is offline
Old 06-26-2013 | 06:32 PM
  #7541
https://www.youtube.com/watch?v=4io4Gvzejxo
this is with csi blue pistons and stock springs all around . 37 front oil and 32 rear . not bad but a little loose. crappy tires and I can't drive
rythby is offline
Old 06-26-2013 | 06:52 PM
  #7542
T. Herwig's Avatar
http://oi39.tinypic.com/ekp1mw.jpg
Fits really well... I like it a lot.
T. Herwig is offline
Old 06-26-2013 | 07:09 PM
  #7543
protc3's Avatar
Sweet paint job bro.
protc3 is offline
Old 06-26-2013 | 07:12 PM
  #7544
hey herwig, did you post a setup??. o wait....found it
rythby is offline
Old 06-26-2013 | 07:13 PM
  #7545
CarlCrocco's Avatar
I did a nifty mod to fit the XERun 150 perfectly in the EB48
Attached Thumbnails Tekno RC EB48 Thread-hobbywing2.jpg   Tekno RC EB48 Thread-hobbywingeb48.jpg
CarlCrocco is offline
