Tekno RC EB48 Thread >
Like Tree2Likes
Old 02-24-2013 | 03:33 PM
  #4936
LAZNICK RC's Avatar
Originally Posted by streetsports
Yah the spring is still weak...also on my buggy and woodys buggies today I noticed that the steering doesn't center very well even though the servo is...I figured its probably the two plastic saver halves sticking together or riding on a flat spot....which is no good...I turn to the left and it sticks to the left a bit...and same when I turn back to the right...I have my endpoints set correctly also...I would love to see someone make the upper half of the saver out of aluminum...
Other than that the buggy was awesome...puts my rc8.2 to shame IMO...also today was around 55 degrees and neither buggy broke an arm and we have a nice track with big jumps...right now there's a jump that shoots you up 12 feet and out 30-40.
Edit: I stripped the factory servo horn really easily also so I definitely
recommend an
aftermarket part here like the hot bodies one that everybody seems to be running
Hi
So tekno have said they have improved the spring on the second run kits is this true or it needs to be improved still
LAZNICK RC is offline
Old 02-24-2013 | 04:10 PM
  #4937
I'm having problems with the servo saver spring too. Is there a new Tekno spring available? Any other brand springs known to work better?
nougat is offline
Old 02-24-2013 | 04:17 PM
  #4938
patrick lsp's Avatar
new kit on the way. what batteries does everyone like? i prefer as big as i can go to be able to make outdoor 10 minute mains. not looking to drop $200 a peice. i did search this subject but didnt find much info. thanks
also what size and c ratings? what is minimum c rating that will work with rx8 and 2050 combo?
patrick lsp is offline
Old 02-24-2013 | 04:26 PM
  #4939
advpball's Avatar
try value hobby..I used for 10min main with couple practice laps before and after.
advpball is offline
Old 02-24-2013 | 05:02 PM
  #4940
subaru_tech's Avatar
here's the link
http://www.valuehobby.com/power-syst...200mah-4s.html
subaru_tech is offline
Old 02-24-2013 | 05:16 PM
  #4941
Rockthecatbox21's Avatar
Think smc 6500 4s.
Rockthecatbox21 is offline
Old 02-24-2013 | 05:30 PM
  #4942
smc's out of stock. anyone ever run a 20-30c 5000 turnigy? is that to low of a c rating?
Old 02-24-2013 | 05:59 PM
  #4943
Suspended
I've been running them for years now with zero issues. A few of my buddies all run them too with the same results. I can run with any buggy on the track with my el cheapie turnigy....
MattP is offline
Old 02-24-2013 | 06:16 PM
  #4944
Originally Posted by LAZNICK RC
Hi
So tekno says they have improved the spring on the second run kits is this true or it needs to be improved still
My buggy is the newest release
streetsports is offline
  #4945
Same here. I have even used them in a truggy with n adverse effects.
MX304 is offline
Old 02-24-2013 | 06:23 PM
  #4946
Same here. I have even used them in a truggy with n0 adverse effects.
MX304 is offline
Old 02-24-2013 | 06:33 PM
  #4947
LAZNICK RC's Avatar
So you have the newest release and still have problems with servo spring why then tekno state that they have fixed it with better servo saver spring !
Do they need to address this ongoing problem with a stronger servo saver spring!
Old 02-24-2013 | 06:44 PM
  #4948
RC_Woody's Avatar
Yah the spring is still weak...also on my buggy and woodys buggies today I noticed that the steering doesn't center very well even though the servo is...I figured its probably the two plastic saver halves sticking together or riding on a flat spot....which is no good...I turn to the left and it sticks to the left a bit...and same when I turn back to the right...I have my endpoints set correctly also so its not forcing it out of place...I would love to see someone make the upper half of the saver out of aluminum...
Edit: I stripped the factory servo horn really easily also so I definitely recommend an aftermarket part here like the hot bodies one that everybody seems to be running
Well scratch that on arm not breaking, 3 pack through, snap To be fair though it was on the quad, and I didn't hit at the perfect angle that tends to break arms. Already ordered the new ones. I'm not sure what is going on with why our servos wont center. Torque shouldn't be it, I'm running the 7955 servo. I will have to take a closer look when I start cleaning and waiting for my arms to show up.
RC_Woody is offline
Old 02-24-2013 | 06:50 PM
  #4949
Suspended
Even my spring on my second sct410 seems a little too soft. I have it just about locked down. Hoping Tekno releases a better servo saver spring.
MattP is offline
Old 02-24-2013 | 07:16 PM
  #4950
gtsakiris's Avatar
Just wanna throw a shout out to Geoff Arnold for hooking me up at motorama with some parts for my EB48. I only got it two weeks before the race and was short on some spares. Without his help I wouldn't have been able to race the mains and make the bump. Thanks Geoff! the EB is an awesome car, I've been running the 8 for several years and out of the box the car bumped up my laps a full lap right on the initial run, and I hit my best overall lap times I've ever seen a my local hangout South Jersey RC.
gtsakiris is offline
