Tekno RC EB48 Thread
#4803
I tried the CSI blacks last Friday. Pretty cool piston. Used the same oils as I would have used with the stock undrilled pistons. Buggy had just a touch too much pack for the track but it wasn't bad so I left them in. I'm going to try the blues next time.
#4804
This buggy continues to perform. I have not raced in over a month and got 2nd in our A Main. I love this car.
For the first time, the car is sounding a little strange at high RPM. Bearings seem to be OK at low speeds. Kind of like a crunching sound. It's got full power. I guess I have to look at the diffs.
#4805
continue enjoying !
#4806
#4807
It's strange because I got this car when it first came out. I did not put the shims in the diffs. I got the new rear diff coupler and drive shaft. I have only broken 1 A arm the entire time. The gears on this car on tiny. The diff case is also small. Kind of cool if you ask me. I wonder if the diff gears are gone. It's like a crunchy, flapping noise when you hit full throttle and the rear drops down. You also hear this noise during a jump when you spin the wheels in the air. I switched from VP PRO oils to Team Associated oils. Still at 5,5,3.
I will pull the car apart tomorrow. The car still has full power. I will check the spur gear.
#4808
#4809
Now that I think about it....the rim on one of my rear tires has a small notch in the back part. That has to be it.
#4810
I am surprised that with just the CSI piston change you had more pack than the 10x 1.1s; did you change the stock bladder?
#4812
I was gonna wait 'til I actually have mine and installed, but this already seems to be going around on Fb so,
A friend and fellow racer has recently started making chassis skinz. So, I contacted him about one for the 410, which being the chassis is the same, also will work on the EB48.
https://www.facebook.com/TwistedSkins
I'll post actual installed pics once I get mine which should be probably sometime next week, I think.
http://www.rctech.net/forum/painting...sis-skins.html
#4814
You have tekin motor right which is delta wound they do have slightly more top end then Y wound motor . The Y wound motor gets up through the rpm range a little faster on take off hence slightly faster acceleration but the delta pulls away at the top end but remember the delta is not as efficient producing that extra rpm / torque will draw more current thus producing higher temp so Iam thinking a good starting point for an outdoor track would be 17t on the motor you have
#4815
Hello
2Likes
