Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-18-2012 | 11:07 AM
  #1531
Allen Drebi's Avatar
Originally Posted by rcmiket
I give up on the shocks!! I've got three hours trying to get them to stop sucking air, but no luck. The bladders are just a little off. They don't seat in the groove in the cap tightly enough . I'm going to run them as is until I can find better bladders. The mugen bladders were a no-go. Anybody got any ideas? I want to race tomorrow, so I can't spend anymore time on them today (honey do list), I'll run her as is.
Do not install the bladder inside the cap than install the cap onto the shock
After you have filled your shock with oil to the top, install your bladder directly onto the shock body. Pull the shaft down 3 or 4 mm. This will create a vacume and hold/seal the bladder in place. You will have some oil spill out at this point. That is ok, just clean carefully. Do not break the seal of the bladder to the shock body. If you do, repeate the steppes. Screw on the cap with the bladder sealed by hand all the way down to hold the bladder. Than set your rebound and screw the cap more using a wrench
See if this helps
Allen Drebi is offline
Old 08-18-2012 | 11:12 AM
  #1532
Oldanski311's Avatar
Originally Posted by sjenkins97
Rear camber links-if you try from the top down they are a bear. however if you start at the bottom of the rear hub they seem to slide up into the correct location easier. it is like the rear hub is tapered wide bottom narrower at top. hope this makes sense.......
+1 I did the same thing.
Oldanski311 is offline
Old 08-18-2012 | 11:15 AM
  #1533
dam
Hey Steve - Are you going to have that ready for the Shootout?
dam is offline
Old 08-18-2012 | 12:00 PM
  #1534
jones8352's Avatar
Originally Posted by Ironwolf1974
Ok at the track, need to know what pinion for 2050kv motor please!!
Depending on the size of your track a 17t will give you about 39mph and a 18t will be about 41mph.
jones8352 is offline
Old 08-18-2012 | 12:28 PM
  #1535
Allen, thanks for the help, but been there, done that. No luck. When the shocks are complete, they seems fine. Pump them a dozen times, OK. Wait a few minutes , pump them again, large amounts of air. I think I can actually hear the bladder pop loose, then air pocket. And yes, the caps are tight as all get out, but the bladders are not cut, or showing signs of uneven seating on the shock body. I'm baffled.
rcmiket is offline
Old 08-18-2012 | 12:40 PM
  #1536
Dan's Avatar
Dan
Seeing these sexy new built buggies is making me want one. I was going to wait until any quirks are sorted out (like my V4 conversion)...but so far, seems like I haven't read of anyone running into real problems with it.
Keep up the good work and continued personal support for the Tekno fans Danny. I just rebuilt my Ve8 but when the next teardown comes, its time to start with a new EB48.
Dan is offline
Old 08-18-2012 | 12:57 PM
  #1537
Matthew_Armeni's Avatar
When you say "tight", are they really tight? When we build them we hold the body with pliers and twist the cap on with a screwdriver through the eyelet. The cap is designed to bottom out on the shock body, crushing the bladder just the right amount.
When you open your shocks, is there oil above the bladder?
Also, do you think air could be getting in through the o-rings at the bottom? Did you use Green Slime or an equivalent? Did you crank the bottom cap as tight as you could? Is there a chance one of the o-rings was torn during assembly?
Matthew_Armeni is offline
Old 08-18-2012 | 01:05 PM
  #1538
Originally Posted by Hack-N-Slash
I know I saw one person mention binding in the steering knuckles, did we figure out whats causing that?
When I put the center diff into the bulkhead I found that the spur hits a little on the top plate. I saw someone post about counter sinking the holes will fix that, which holes are being referred to.
Overall I've had very few problems with this build. Just minor clearance issues. Those rear camber links were a beast to get into the bearing carrier.
Here's the post explaining the steering knuckle bind and how to fix it.
Old 08-18-2012 | 01:54 PM
  #1539
Thanks, I thought I had seen every page of this thread so didn't think to search here for it.
Hack-N-Slash is offline
Old 08-18-2012 | 02:07 PM
  #1540
BashemSmashem's Avatar
Here is a few pics of mine painted up and ready !
and an under the hood shot ....
BashemSmashem is offline
Old 08-18-2012 | 02:22 PM
  #1541
Nice color, it must have taken forever to paint that
You won't have any problems losing sight of it from the driver stand
Old 08-18-2012 | 02:52 PM
  #1542
teknorc's Avatar
Try sanding the bottom of the caps so they can seat down farther on the bladder. Just a touch, test and repeat if necessary. You could also try removing the o-ring that goes around the top threads. Let us know how it goes.
teknorc is offline
Old 08-18-2012 | 02:58 PM
  #1543
Thanks , its not that bad once you have done it a few times .......
Old 08-18-2012 | 04:13 PM
  #1544
cant run shootout unless wife changes her mind.....a bit bummed..
sjenkins97 is offline
Old 08-18-2012 | 05:08 PM
  #1545
dam
Major Bummer. I just got the wife pass. I was looking forward to watching your new ride!
dam is offline
