Share your 17.5 blinky setup
#17
Veh: B4/B4.1 +8mm
esc/motor: Tekin RS Pro/Express Motorsports rev tech 17.5
Motor Timing:1 line short of max
Gears; 34/75
FDR: 5.74
Bat: Turnigy 6000mah 65C
Temp: 140*
Track Size: indoor 125 x 65 high bite clay
Gears; 34/75
FDR: 5.74
Temp: 140*
#22
I have it in 2 cars...
Vehicle: TLR Losi 22
Motor: Orion 17.5t
ESC: Orion R10
Motor Timing: 20 deg
Gear (pinion/spur): 34/72
Track size: med/large indoor clay
Vehicle: Team associated
Motor: Viper RC 17.5t
ESC: Viper VTX10
Motor Timing: 35 deg
Gear (pinion/spur): 25/76
Motor: Orion 17.5t
ESC: Orion R10
ESC: Viper VTX10
#23
Vehicle: TLR 22 rear motor (Frank Root indoor clay setup)
Motor: Novak Ballistic 17.5
Motor Timing: 45 deg
ESC: Novak GTB II
Gear: 76/31-32 (depending on the track)
FDR:
Track size: Small
battery: SpeedZone 3800mAh 60C shorty pack
ESC: Novak GTB II
FDR:
Track size: Small
#24
#27
Associated B4.1
Tekin 17.5
Tekin RS
No timing
Gear 72/30
Indoor medium clay track
I need more top end but like the low end torque. Do any of you run with weights on the car? I have a problem with the car pushing out of corners.
Tekin 17.5
Tekin RS
No timing
Gear 72/30
#29
can i ask for some gearing help?
now:
losi xxx-sct
tekin rs blinky
reedy sonic 17.5
stock timing 20 degrees
78/23
thunder power g6 pro race 5300 65c 2s
sdrc raceway: med to high bite indoor off road clay track
i think i need to go to a smaller spur gear. my motor was toasty after a 10 min run. i was getting killed on the straight by a tekin 17.5. what fdr should i aim for and why?
now:
losi xxx-sct
tekin rs blinky
reedy sonic 17.5
78/23
