-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   Share your 17.5 blinky setup (https://www.rctech.net/forum/electric-off-road/590995-share-your-17-5-blinky-setup.html)
RaceRoc 01-24-2012 08:02 AM
What works best for you?
Vehicle (B4, 22T, etc.)
Motor (Tekin, Novak, etc.)
Motor Timing
Gear (pinion/spur)
FDR
Track size (small, Med, Large)
Thanks!
stu541 01-24-2012 08:31 AM
Vehicle (Team C Pro roller with Evo conv.)
Motor (Viper VTX10/Motor)
Motor Timing (3200 drive fz blinky mode; 45deg timing on motor)
Gear (27/75 AE)
FDR (7.25)
Track size (60x40) indoor carpet offroad
:nod::nod::nod:
Glowster21 01-24-2012 08:37 AM
Vehicle : Ultima SC-R
Motor: Viper VTX with a Viper ESC
Motor Timing: 35 Degrees
Gear : 28/72
FDR : 6.69
Track size : Medium track with medium to high bite
brent701 01-24-2012 08:40 AM
Vehicle- B4.1 FT
Motor - Viper RC VST17.5T
Motor Timing - +15 (45 total)
Gear (pinion/spur) -33/72
FDR -5.67
Track size (small, Med, Large) --Small.
Gearing makes the buggy FLY. I was trying lower gearing for a high FDR and it moved but not as well as it does now.
gene1219 01-24-2012 09:45 AM
Vehicle TLR 22 mid motor
Motor Speed Passion Club Cirtix 17.5
Motor Timing factory
Gear 32/70 but will be trying out a 34/70
FDR
Track size Large
battery: 25c Gens ace 4800 saddle
*notes, this is a $90 speed control/motor combo and works really well. I think I can eek out a little more power if I move up to a better 17.5t motor like a D3. Also a better battery may also provide more punch too. However it's been really good and smooth on power where I can focus on driving and running clean lines.
Lenman73 01-24-2012 01:53 PM
Team-C tco2
Tekin redline 17.5
Timing 45
69/30
5.98 fdr
Large indoor clay
Out of the hole it didnt pop but was fast down the straight.
Racecrafter 01-24-2012 05:20 PM
Vehicle Tamiya 201
Motor Speed Passion GT 2.0 pro
Motor Speed Passion 17.5MMM
Gear 34/72
FDR 5.50
Track size med-lrg
cghomann 01-24-2012 09:18 PM
B4.1 +8
revtech 17.5
hobbywing justock
36/72
fdr 5.2
medium to large outdoor track
Jerz616 01-25-2012 12:50 AM
[QUOTE=RaceRoc;10219279]What works best for you?
Vehicle (FT B4.1 +8.)
Motor (Fantom Apex.)
Motor Timing- 3 clicks past center.
Gear (72/35)
FDR- 5.3
Track size (Med/Large indoor clay)
Shimmy 01-25-2012 02:22 AM
Vehicle: X Factory X6 Squared
Motor: Hacker 17.5t
ESC: Hobbywing XeRun 60A
Motor Timing: N/A
Gear (pinion/spur): 31/69
FDR: 5.79:1
Track size: 37m x 20m
jimkoimanis 01-25-2012 04:29 AM
Vehicles
Team durango dex 410
Esc nosram tc v3
17.5 motor max timed spur 80 pinoin 37 final drive 5.2
Very fast but coulp secrets to keep temps down
Team durango dex 210
Esc lrp sxx stock spec v2
17.5 max timing
Spur 69 pinion 36 final drive 5
EricJ 01-29-2012 01:23 AM
Vehicle: B4.1FT (stock chassis)
Motor: Viper VST 17.5 / Tekin RS
Motor Timing: 45 (+15)
Gearing: 69:39
FDR: 4.60? Not sure.
Track Size: Large to Very Large Indoor (equivalent to Medium-Large outdoor tracks), medium-high bite.
Ambient: 60s-70s
Post-run motor temp: 120-130F (practice to race, and never exceeds these after much longer runs)
TC5AE 01-29-2012 11:02 PM
Vehicle: B4.1
Motor: RevTech 17.5
Motor Timing: 2 lines past center
Gear: 37 pinion 75 spur
FDR: 5.27
Track size: Medium
trickedout 01-30-2012 03:05 PM
Vehicle - Sc10
Motor - D3 17.5t / Tekin RS
Motor Timing - Full motor timing/Blinky ESC
Gear - 25/75
FDR - No clue
Track size - Indoor Med Bite Medium/Large track
Motor Temps - 130-150 after 6min
Halve 01-30-2012 09:44 PM
Kyosho RT5
Tekin speedo
Reedy Sonic 17.5
50 deg timing in the motor
24/75 8.12 FDR
Orion 90C battery
150 temp after 8 min
small indoor clay track :tire::tire::tire:
