RC10T4.1 Thread.
#31
Going to give my truck a try tonight at the track. Installed the 19t pinion, rebuilt the shocks, and got some barcodes for the front. Hopefully my lap times will improve. Just gotta remind myself, baby steps, baby steps.
#32
Super Moderator
Trader Rating: 31 (100%+)
love your sig. that's funny
#33
True story...
#34
Tech Legend
so for the factory Team T4.1, are they coming with carbon front a-arms or are they going with a standard plastic a-arm?
Reason I ask is that when looking into my SC10FT for parts, i noticed the stock number for the a-arms was the same as the regular SC10s. Heck, a lot of the parts are the same material.
#35
Super Moderator
SC10, SC10 FT, T4.1, and B4.1 all have the same plastic. If you want carbon parts for any of them you have to find the carbon specific part numbers from the original T4/B4. T4/B4 had carbon and plastic parts so make sure you get the right part number.
#36
Regarding fluid in a gear dif. I remember from way back in my 1/8th days we used to tune with different fluids in the diffs. Why is it when I ask about running different weight fluid in this gear diff do people look at me like I'm crazy and tell me to stick with the grease? Can this gear diff not be tuned in a similar fashion? If so, what weight fluid would be a good baseline equal to the grease from the factory? I've been told 3k is similar.
#37
Think of it in full size car terms, a bigger pinion would be like starting in second gear, less torque. A bigger pinion will put more load on the motor taking away some "punch". Be careful though, you go to far and you'll wind up with heat issues.
Not needed, slipper adjustment, gear mesh or a worn pinion gear can be causes. Yes they make them but really are a waste of money and don't really fix anything. With correct gear mesh and slipper adjustment the stock spur can handle insane amounts of power.
#39
Everyone's given great advice for your issue. Just wanted to add that I find a tiny dab of thread locker on my motor screws helps to keep the motor from moving after a good tumble. Before I used the thread locker, after a crash my gear mesh would be off, thread locker fixed that.
#40
Race my truck with bb springs last night and it did good not a big difference but seem to have a little more traction all around and little better jumping. I used siver rear 22 springs in front and yellow rear 22 in the back with traxxas 3768 upper/lower spring retainers they work good just have to get two of them cuz only come two to a bag but they r only 3.00 ea.
#42
#43
Ran my truck last night with the 19t pinion and the battery spaced slightly forward with a single foam block. Also added some barcodes up front. Wow, what a difference in handling and performance. Truck is actually controllable now. I just need to learn how to drive it.
Problem I've been having is my speed control keeps coming loose after a crash. Regardless of the servo tape I use, or how clean the contact surfaces are, it still comes loose. Any suggestions?
#44
Trader Rating: 123 (100%+)
Is anyone Doing the hex conversion for the B4 front end on to your T4?
I just ordered the parts, plan to use the axels and spacers properly to just run my current Rulux rears without the hex, just the pin like the current rears are on the T4.
If you have any experience with this, post up!
#45
Super Moderator
If you use those red rags and wash them......don't wash them with anything else unless you want it pink
