RC10T4.1 Thread.
#406
#407
I ran green 22t frt springs and pink buggy rear. Worked well
#410
Besides springs, can someone please list the additional parts needed to convert the T4.1 to big bore? I don't need part numbers, just the brand and what it is. Also, how is it that the big bore don't rub the front shock tower or rear turnbuckles? Tolerance looks awful close.
#411
#413
#414
I use the Ghea shock collars up top
http://www.ghea.se/GHEARacing.php
and then the losi bottoms from the 22.
http://www.amainhobbies.com/product_...Cup-Set-TLR-22
#415
Where is a good place to buy the Ghea stuff in the US?
#416
Never fast enough right? 11.1 Volt? or not
Im running a new V540 3300kv+80A Waterpoof ESC Combo with a Venom 7.2v 2s 5000mah 25c battery. 18 tooth pinion and 87 spur. I want more power and speed without killing my esc and motor. my buddy had his stampeed over whipping my @ss! he has a 3s 3000mah 11.1v. CAN I RUN A 3S in this T4.1??? Can I not Fry my combo also. its says 2-4 lipo on the instructions. any input would be great! brad
#417
http://www.amainhobbies.com/product_...rs-Upper-Lower
what you can also use for the upper, in combination with the stock threaded collar.
#418
#419
easier to adjust. with the traxxas retainer you need to pull the spring down do adjust the stock aluminum collar.
the ghea collars allow for slightly more adjustment on the spring, they take up the same amount of threads as the stock collar. this is more an issue on the buggy than the truck, and then it only seems to be and issue with a stiffer spring in the rear.
