Like Tree1Likes
TLR 22T Thread
Old 01-13-2012, 05:20 AM
  #1471
Originally Posted by Corey Bernardo
bombertodd = awesome sounds good bud, and congrats again!!! Keep it going..
I have the lexan pieces of the under tray body if you will screwed into the sides on the plastic chassis protectors.... with velcro...
So Corey, are you saying you cut the wings of the body off and screwed them to the bottom, aka underside, of the plastic chassis extensions?
losi b is offline
Old 01-13-2012, 06:08 AM
  #1472
looking at it id say he kept the flaps on the body and used other pieces on the chassis and then the two vlecro together?
Speedy Steve is offline
Old 01-13-2012, 06:59 AM
  #1473
Maxxingout's Avatar
Trader Rating: 17 (100%+)
So as everyone used all parts from the kit or are there some should/must have upgrades? I know someone bought the lunsford ti links set but that's all I can think of. I should be getting mine sometime next wk so just looking ahead to be ready.
Maxxingout is offline
Old 01-13-2012, 07:14 AM
  #1474
Trader Rating: 19 (100%+)
what size is the battery compt when using this in a mid motor set up?
muck is offline
Old 01-13-2012, 08:29 AM
  #1475
AssocRacer's Avatar
Which toe block does it come with? Also, I'm assuming it DOESN'T come with the carbide diff balls?
AssocRacer is offline
Old 01-13-2012, 08:30 AM
  #1476
bombertodd's Avatar
I'm running:
Front aluminum camber block
Rear aluminum camber block
Front Ti-nitrade threaded kingpin
Rear threaded hinge pins
Tungsten carbide diff and thrust balls
Aluminum battery holder
bombertodd is offline
Old 01-13-2012, 08:34 AM
  #1477
Team Tekin
TY@TEAMTEKIN's Avatar
Should have mine Monday or Tuesday! Can't wait.
TY@TEAMTEKIN is offline
Old 01-13-2012, 08:57 AM
  #1478
It comes with the 3.0LRC toe block and standard hard balls, not carbide.
hacker07 is offline
  #1479
cavwrench's Avatar
Trader Rating: 128 (100%+)
Here is a pic of mine all done up. Just waiting to go to work today to put tires on it. Can't wait to get it on the track.
cavwrench is offline
Old 01-13-2012, 09:09 AM
  #1480
rob martin's Avatar
Trader Rating: 66 (100%+)
Does anyone else feel the surge that the 22 and the 22T have brought? As much as i hated to wait months to get the truck it really makes you appreciate it even more now that it's here
rob martin is offline
Old 01-13-2012, 09:11 AM
  #1481
AssocRacer's Avatar
And what springs does it come with?
Old 01-13-2012, 09:32 AM
  #1482
It comes with pink and green truck fronts and pink truck rears.
hacker07 is offline
Old 01-13-2012, 09:34 AM
  #1483
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by bombertodd
What are the tabs made out of that are connected to the chassis?
Those are made from Lexan. Dustin, Mike, and a few of the guys on the team, just cut and bent lexan to make a flat velcro surface.
I'm running:
Great List...
I would add the RTR shock caps also and I would add the Ti Parts in this order:
Shock Mounts
Turnbuckles
Ball Studs
Frank Root is offline
Old 01-13-2012, 09:36 AM
  #1484
AssocRacer's Avatar
Thank you. I noticed that Dustin Evan's set up calls for buggy pink springs, why the buggy springs?
Old 01-13-2012, 09:57 AM
  #1485
bombertodd's Avatar
Frank, when will the Ti turnbuckles be released?
