TLR 22T Thread
#4651
TLR6023 (10mm ballstud)
#4653
I just put the 10mm thread ballstuds on the camber block on both my T and SCT. if I break another camber block, then I guess I will have to go to aluminum blocks
i even put the little associated dust covers
#4654
I think I have the SCT front camber block on my 22T. I have 2mm, so and i have your setup, so i think that equate to the 4mm on the set up.
#4655
#4658
Looks good xxx-dad. Nice highlights. Must have been tough to mask.
Here is mine.
Here is mine.
#4661
ya im using the bulldog body on mine they look sweet and work good to.
#4662
Hey guys! I just noticed that the transmission in my 22T RTR is kinda tight! I took it apart and everything looks good in there and it spins freely while it's opened but then when I screw the halves together (even gently) it binds up a bit to the point where it will spin my diff rather than the spur if I turn it by one outdrive. My other cars have a much freer drivetrain. I only have Am I doing something wrong here? Is it supposed to be like this? The truck only has 3 packs through it. It seemed to drive well enough but I am concerned that the tight tranny is putting unnecessary stress on the electronics (and making my car a bit slower)
#4663
#4664
