TLR 22T Thread
#3587
My 13.5 boosted 22T is having diff issues. With the diff all the way tight the diff is still slipping. I have to run the slipper a bit loose to even drive it. Is it time for a rebuild?
#3588
#3591
Any update on if people are using standard size stick lipos or shortys on the 22T?
If using shortys, what position are most people using for position of the shorty pack in the 22T?
Thanks for any info in advance.
Allen
Allen
#3592
I only use short packs in both my 22 and 22t. On the 22T I use them all the way back with one pad vertical between the pack and the tower, and another spacer up front against the battery holder.
For med to low bite, short pack all the way back against tower, one pad laying down in front against battery holder.
Truck rotates better, jumps better, lands better and corners better for many of us with a short pack. So many of us use them 100% of the time on our Florida based tracks. CA type surfaces and traction are very different so you may get different opinions from there or from racers from different surfaces.
Basically box stock setup works great here, with short pack all the time.
FYI: Modified class racer only, 7.5 to 8.5 motors only used so far in the 22T. Main tire of choice is either an MC Suburb or Blue Compound Barcode, but same tire front and rear.
#3593
I only use short packs in both my 22 and 22t. On the 22T I use them all the way back with one pad vertical between the pack and the tower, and another spacer up front against the battery holder. For med to low bite, short pack all the way back against tower, one pad laying down in front against battery holder. Truck rotates better, jumps better, lands better and corners better for many of us with a short pack.
I typically run the battery with 1 one pad laid down in the rear under the tower. Sometimes I go with 1 pad stood up if traction is low.
#3594
So my son was able to run his 22T, for the first time, in a track. one thing i noticed that the rear end likes to go first and loose control when turning into a turn, using a gear diff with 3k lubem track is a loose, using a 30' kick up Plus 3' caster, tires is barcodes, it has lots of traction but the only problem is when turning,i think its something to do with the gear diff.
any thoughts....
any thoughts....
#3595
Maybe it's just too much front traction? It sounds like basic car setup.... make one change at a time and see where you get.
More Steering Mid-to-Exit of the Corner and On-Power:
* Thicker oil in Front diff
* More caster
* Lean front shocks down on tower
* Thicker rear swaybar
More Steering Into the Corner:
* Thinner oil in front diff
* Less caster
* Stand up front shocks on tower
* Front upper link down on tower
* Short ackermann plate
* Steering link back on Ackermann plate
* Thinner rear swaybar
* Lean rear shocks down on tower
All taken from:
http://jq-products.com/the-news/43-t.../160-the-guide
* More caster
* Less caster
All taken from:
any thoughts....
any thoughts....
#3596
any thoughts....
any thoughts....
#3597
* More caster
* Less caster
All taken from:
* More caster
* Less caster
All taken from:
Thanks guys...
#3599
* More caster
* Less caster
* More caster
* Less caster
Thanks again.
Allen
#3600
any thoughts....
any thoughts....
