TLR 22T Thread
#2088
I got the front end done so far... Going together good for my first kit ever! It has taken me around 2hrs to do it though.. I was using the L wreches then I got inpateint and went and cult the L part and put it in my drill LOL... Should be way faster today; I can't wait to drive it
What motor should I run you guys think?
#2089
I've run mine for several race nights now, and I've run my 22 since about Thanksgiving of last year and both of them have less slop in them then my B4.1 and T4 had right out of the box. I haven't had a single issue with my 22, but I've pulled three ball studs out of my 22T and popped a few ball cups off. I think that the kit needs to include the longer ball studs because of the number of shims the kit set up requires under them. I switched to 8mm and 10mm ball studs and haven't had one pull out again.
#2090
#2091
IF you are fairly new to racing, DO NOT start out with a modified motor. If you do, plan on keeping lots of extra parts in your box because you will break all the time. I've been racing for several years and am still faster with a 17.5 then I am with an 8.5. Stick with stock until you learn throttle control and smoothness.
#2093
ball cups
do rpm ball cups fit on the 22 and 22t turnbuckles?
#2094
When you say aluminum camber plates are you talking about aluminum adjustable hinge pin holders? Like on the Losi SCTE that have different plastic blocks to give different Anti Squat?>
Also Is the steering rack on this truck a Slider type or bell crank type setup'?
I remmber seeing a video about the slider but cant remmber if it was for the 22 or 22t.
Also Whats the cheapest place to order one of these ??? I know someone said Amain's price went down after pre-oder shipping.
#2095
alum camber plates.
Front
http://www.tlracing.com/Products/Def...ProdID=TLR2059
Rear
http://www.tlracing.com/Products/Def...ProdID=TLR2060
22 and 22T use the same slider steering system.
#2097
#2098
They make speed tips for using "drills". Make sure your drill has a good clutch so you don't strip out all your plastic parts!
#2099
Well I'm not really new but not no more I would say I'm more in the middle. I was thinking 13.5...
Also does it go like this:
Image is big sorry click the link below:
http://i.imgur.com/7aol4.jpg
Also I know it goes on the ball but I think you guys know what I mean..
#2100
Buy once and an 8.5. Only get an 17.5 etc if there is already a extensive class for it. Turn down punch in your esc.
If you break learn from your errors and buy spare arms and tower. Shock shafts etc.
