RC10B4/T4 Forum
#1442
Hey guys, I just got a couple of JR 8800s servos for my B4/T4 and was wondering which spacers to run if any on the mounts. The manual doens't state, but the 8550 and 8800 have the same case and for that it says no spacer. When I mount it without the spacer it's just barely touching the wall that separates the servo from the battery (you can almost slide a business card in the space). If I use the small spacer like with the Z590 does, then the space behind the servo looks better, but the steering rack almost touches the servo...everything clears, but it's close. Which way is better?? Spacer or no??? Just want to make sure I have it mounted correctly. Thanks.
#1444
is the FT T4 still competitive??? I am trying to figure out if thatss the way i want to go now.... or stick with a MF2...
#1445
#1446
well, i used torace. I used to race the BK2/MF2/XXX4. I lvoed em... but no one is offering me a packag deal on one... like, to get everything going again.. but i have a package deal on a FT T4... i just dont know what i want to do
#1447
#1448
trying to gear my new ft t4 i just got, i have a team orion core stock (with v2 head) and a gt7, i have a 81 tooth spur on it, what pinion would you guys suggest? i have a 20 tooth on there, but it seems to run alittle on the hot side. would 81/18 or 81/16 be better?
#1450
i only have evens lol 16,18,20,22, 24
#1451
The 18 will work since you don't have a 19. You will sacrifice a little top speed is all. I'd get a 19 though, as it is the do-all pinion on the T4 most of the time.
Are you racing? New to rc? Do you have access to comm lathe and such? Just asking as if it's been run hot a few times you may want to cut the comm soon.
#1452
not so new to rc, but i was wondering with the 81 spur if 18 or 16 would be best hah, it never was hot for very long just was sitting here breaking in my new orion stocker just seemed alittle warm
