RC10B4/T4 Forum
#5941
Thanks for the info about weight. I started the season with 4 Ener G 4600's. I have added 2 Orion 3800 30C lipo's to the mix. The car has been about 2 tenths a lap faster with the lipo's without adding any weight. I just want to meet legal weight when I go to Lipo full time so that I can add smaller amounts just where I need it.
#5942
58 oz
your best performance...
#5944
What do you guys use to weigh your cars?
#5947
oh ok, ill look into getting one, instead of guessing on the weight of everything.
#5948
#5950
#5953
17.5/13.5 Gearing
Guys I've found another solution to properly gearing 17.5's and 13.5's while using a slipper. I think it's a little more simple than others, BUT it does take some older yet still able to find parts.
Parts needed:
RC10/T/B2/T2 outer slipper plate. (not t3/b3)
RC10/T/B2/T2 slipper disk (not t3/b3)
Bearing/bushing, size??? x1
1 Rear axle bearing spacer (the one thats in between the bearings in the rear hubs of b2,t2,b3,t3,b4,t4)
Standard spur
Spur gear screws x2
Installation:
Remove slipper setup, leaving the inner plate only.
Install B2 outer plate with slipper pad.
Insert bearing
Slide rear bearing spacer onto shaft
Slide slipper spring on and install nut
Attach gear with screws.
Done.
Parts needed:
Standard spur
Spur gear screws x2
Installation:
Insert bearing
Done.
