Like Tree55Likes
RC10B4/T4 Forum
Old 08-21-2007, 07:09 PM
  #2536
POUNDITRACING's Avatar
Originally Posted by Jake S
im not sure about this, but if your running 19turn, id look at the new orion 07 element, its a great motor, if your looking for a checkpoint-like setup the orion 07 v2 is a nice motor, just need to be geared for that "sweet spot"
If you have any gearing Q's just send me a PM.
POUNDITRACING is offline
Old 08-21-2007, 08:21 PM
  #2537
K_King's Avatar
Trader Rating: 47 (100%+)
Originally Posted by OTE_TheMissile
The ones made of metal.
there's an option for that?
Umm yes smartass there is. The FT has aluminum with a small screw, and the other ones run steel.
K_King is offline
Old 08-21-2007, 09:01 PM
  #2538
Suspended
I like the aluminum ones because they sheer off very cleanly and don't take any other parts with them if/when they break. I've only broken one in the last year and I probably would have broken other parts if I had been using the steel ones...and the aluminum axles are much easier to replace than any other part on the B4. That might be a messed up way to look at it, but that's my opinion.
Matt Buggy is offline
Old 08-21-2007, 10:06 PM
  #2539
K_King's Avatar
Thanks Matt, do the screws stay in pretty good?
K_King is offline
Old 08-21-2007, 10:57 PM
  #2540
killer89's Avatar
Trader Rating: 41 (100%+)
Yeah they do Kevin. Actually I find they hold too good sometimes. I barely tighten them and after running I have to use some muscle to break them loose.
BTW, if you want to use your Losi front rims, you can do so with a spare set of losi knuckles and axles... Just drill the hole out to 7/16" and use 1 less bumpsteer spacer than you would on the AE knuckles. You can only use the middle hub height though unless you shave the knuckle.
killer89 is offline
Old 08-21-2007, 11:01 PM
  #2541
K_King's Avatar
Does it change the geometry at all? What about the rears? Same offset?
K_King is offline
Old 08-21-2007, 11:20 PM
  #2542
MikeFriery's Avatar
Trader Rating: 19 (100%+)
rears are the same... although the pros will tell you losi wheels have less sidebite cuase they are stiffer normal people wont notice
MikeFriery is offline
Old 08-22-2007, 03:14 PM
  #2543
mfishel's Avatar
I started using a countersunk bolt with a cone washer on my FT front axles. I don't know if its coincidence but I haven't sheered the bolt since.
mfishel is offline
Old 08-22-2007, 03:36 PM
  #2544
K_King's Avatar
Thanks! Do you know about the different colored diff outdrives? I got some in black and another half in like a brown/gray color. Looks goofy HAHA
K_King is offline
Old 08-22-2007, 03:47 PM
  #2545
Jeff K.'s Avatar
Trader Rating: 18 (100%+)
I think the black ones are the lightweight. The brown/gray sorta gunmetalish color are the stock steel ones.
Jeff K. is offline
Old 08-22-2007, 03:58 PM
  #2546
K_King's Avatar
Hmm arent the lightweight ones the ones with holes cut out of them?
K_King is offline
Old 08-22-2007, 04:14 PM
  #2547
Jeff K.'s Avatar
Mine didn't have the holes cut out, they were just machined dimples I guess you could call them.
Jeff K. is offline
Old 08-22-2007, 04:21 PM
  #2548
K_King's Avatar
http://www.losipartshouse.com/servle...5C-cln-/Detail
Ok I was going off that.
My other ones look normal, only different colors.
http://www.losipartshouse.com/servle...utDrive/Detail
Like that, only that part is black and the other side is that color.
K_King is offline
Old 08-22-2007, 04:29 PM
  #2549
Jeff K.'s Avatar
Might have been from anodizing, someone screwed up.
haha, it's plenty strong already and shouldn't give you any problems. The lightweight outdrive just has better acceleration, less rotating mass.
Jeff K. is offline
Old 08-22-2007, 04:51 PM
  #2550
mfishel's Avatar
OK I'll try to clear it up. The lightened outdrives from Associated are the ones with the dimple and are black. MIP used to offer 'Lite Drives', and were drilled completely through. They snapped pretty easily. The standard outdrives used to be hard anodized a greyish color, but are now black. So you just got an older set.
mfishel is offline
