Traxxas 2wd Slash Thread
#2897
Since the shock towers are the tallest point of the chassis, I avoid aluminum. I like the Proline Protrac towers. Stronger than stock, less flex than RPM, and 2 choices for shock mounting, 3 for camber link. My second choice would be the Anza CF towers. Planning on ordering that bellcrank. Combines the aluminum construction and multiple ackermann positions of the Proline aluminum bellcrank with the integral servo saver of the Proline Steering Improver Kit, plus choice of spring tension.
#2898
If you're running carpet off road, I would seriously consider going to a mid motor chassis like Chuckworks offers. ta_man on this forum was selling an early version with a Fast Lane trans and sealed diff a while back. May want to see if he still has it. Chuck's early offerings placed the battery farther forward than the current versions.
#2899
What springs are you using XXX-T front and rears or rears all the way around?
#2901
#2902
Awesome I'll order some tomorrow, how about tires? Off-road carpet track, no traction compounds allowed.
#2904
I was tinkering with my Robby Gordon,LCG chassis, Stock Slash today.
I'm starting to race with Slash titan motors straight outa the bag oil the bushings
and just drive it. I used to buy those BLT Motors other than them lasting longer than a normal slash motor I see no real difference in RPMs.
#2905
We run clay off road, so I'm probably no help on what tires to run. Some tracks won't allow pins, so check that before deciding. I just had an afterthought. For carpet, a Hot Racing sway bar kit and some Bad Horsey grease in the diff may help you get in and out of the corners faster.
#2906
#2907
Aluiminum shock caps are a must. I put traxxas red aluminum caps on my truck.
The red caps look pretty nice with the black Robby Gorden body I use.
#2909
RPM Steering Blocks, and Rear RPM Toe Blocks are also a must.
I was breaking the stock ones and replaced with RPM plastic good to go!
#2910
Hey all -
My kids are racing kids class with their slashes and having a lot of fun but the wheels that were given to me are too deep on the rims compared to stock slash so the rim rubs the arms when turning. Do you know what to look for with rims so they don't bind when turning? Thanks!!'
