Tune With Camber Links >
Like Tree65Likes
Old 11-03-2014 | 10:05 AM
  #1921
RC10Nick's Avatar
Originally Posted by Vinny Cancilla
So, are you saying that all the top drivers in the world are setting up their cars wrong?
If Fred won't say it, I will! They're wrong!
RC10Nick is offline
Old 11-03-2014 | 11:47 AM
  #1922
tazfam2's Avatar
I have a B 44.3 and looking for a low-speed steering is there anything I can do to help me with that with the camber or any suggestions
tazfam2 is offline
Old 11-03-2014 | 12:46 PM
  #1923
bds81175's Avatar
Moderator
Exit steering? Or mid-turn steering? If you need exit steering you could try running a tighter diff (ball diff) or thicker oil (gear diff). You could also run a longer link in front or raise the inside mounting point. This will allow the chassis to roll over further and plant the outside tire hard later in the corner. Also, don't run too thick of an oil in the center to allow the front to pull the car out of the corner. Sway bar in place in the front currently? Try going to a softer sway bar.
bds81175 is offline
Old 11-10-2014 | 03:48 AM
  #1924
Thanks guys for all the information in this thread. And please don't leave this thread forever, Fred
Put some HPI Apache C1 shocks (same as HPI Vorza and HB D8) with white springs on my Slash and have now started to go through all the steps.
Car is a Slash 4x4 LCG 1/8 buggy conversion with TPPower 5670 motor, Alienpower 250A 8S ESC and 8S 4000mAh lipo. Weight is 4.3Kg.
Could somebody please have a look at the push-down and drop-test vids I made? I am not sure if I got it right and what to look for.
youtu.be/ObK4tO_eBe4
(sorry for not embedding the link, the forum won't let me do this because I don't have enough postings yet)
rodizio is offline
Old 11-10-2014 | 05:02 AM
  #1925
That is a video of you running up and down the street.
mackelby is offline
Old 11-10-2014 | 05:16 AM
  #1926
Ah, sorry wrong link.
This is the right one:
rodizio is offline
Old 11-10-2014 | 05:52 AM
  #1927
elex300's Avatar
If you raise the rear inner link that lowers the roll center,correct? So if you raise the outside of the link does that also give you a LRC or raise it?
elex300 is offline
Old 11-10-2014 | 07:30 AM
  #1928
I believe the back is coming up faster. what camera are you using to get that nice slow mo?
mackelby is offline
Old 11-10-2014 | 07:41 AM
  #1929
Cain's Avatar
Tech Legend
gonna start looking at this with a Tekno SCT410. anyone else working on this with a Tekno? would love to hear more.
Cain is offline
Old 11-10-2014 | 07:43 AM
  #1930
Thanks for your judgement. Rear coming up faster would mean I need to reduce spring rate in the rear.
So either move shocks inward on rear a-arm, use softer springs in the back, or use harder springs in the front?
It's somehow completely counter-intuitive for me. But I'm just a basher, so that probably means nothing
Camera is my Galaxy S5 phone with video mode set to Slow motion in 1/8 speed. It then produces a video that is already in slow-motion. Then imported that video to Windows Movie Maker and slowed it down to 1/2 there. So it should be 1/16 speed now
rodizio is offline
Old 11-10-2014 | 07:44 AM
  #1931
Cain's Avatar
Tech Legend
wife has that phone, I'll give that a try and see how it goes too. Figure need a project over the winter
Cain is offline
Old 11-10-2014 | 01:10 PM
  #1932
bds81175's Avatar
Moderator
I will be but I am waiting on my springs to come in. Should be here Thursday of this week.
bds81175 is offline
Old 11-10-2014 | 09:09 PM
  #1933
TZ
Lowering on the hub has same effect as raising on the tower, just not as dramatic, so yes it lowers roll center.
TZ is offline
Old 11-11-2014 | 07:10 AM
  #1934
Raising the outer link (on the hub) will raise the roll center. I've found it will generally add more rear traction.
rcgerber is offline
Old 11-11-2014 | 08:33 AM
  #1935
All I know is that outdoor I run red springs on the back and blue or black on the front and indoor you can be totally the other way round as the track gives loads of rear grip. The oils are similar. I don't think the car would pass the drop test!
Rsimps is offline
