Tune With Camber Links
#2071
I spring balance and oil balance and I have never gotten lighter front oil than rear. It many times is lighter in front than a lot of the fast guys setup sheets show, though. There is an experienced racer at our local track who just went through and spring balanced his TLR 22 2.0 mid motor buggy and came up with a substantially softer front spring. He loves how the car drives now. I'll have to ask him what he found with oils and pistons.
#2072
You are not forgetting that the front shock piston holes should be thinner than the rear shock piston holes right?
Surprisingly enough I managed to somehow balance it with the standard Red 2.5 front and kyosho pinks rear which are a bit softer than standard yellows. 54 rear pistons, 56? front with 27.5wt all round. Drove so-so but didn't want to throw money at it to fix flaws and traded it. Cool good car otherwise.
#2073
Hey I have a question about shock pistons...the numbers on them ie 1.7, 1.3, etc. What exactly does the number refer to. I am assuming it is the size of the hole. The reason I ask is because I have some pistons that came with one of my kits that are a 4x1.0, 5x1.0, and a 6x1.0, and I would like to make the holes large to a 1.3 or 1.4, but I'm not sure what a 1.4 translates to or is that a drill size. Thanks for the help in advance.
Tim
Tim
#2074
I believe its the diameter in mm. 1.4 is just over a #54 bit.
See http://news.bmotorsports.com/faq/dri...es-conversion/
#2075
cool thanks
#2076
Just starting the process and this is exactly what I was looking for! B5M Light white springs front and rear. 1.6 pistons front 1.4 rear. Here is a video I made showing slo mo. Not exactly sure what I am looking for but the rear seems faster than the front? https://youtu.be/BecvbO1Icfo
#2077
The rear doesn't look faster to me. It just appears that you have more travel on the rear shocks than the fronts. The fronts are reaching full extension earlier. I balance everything. I want the same amount of suspension up and down travel all around.
#2078
Excuse my ignorance but your saying springs look good to you I just need to adjust my travel? How do you properly set travel? Ride height? Shock Limiters? I set the ride height by compressing the shocks all the way down and slowly letting off. I also have 2 Limiters front and 1 in the rear end. Shock positions in the middle on front and rear on the towers
#2079
You either need more internal limiters on the rear shocks or less up front.
#2080
#2081
Interesting thing I found out recently is AE must be watching this thread. I just built a b5m lite and the springs that come in the kit along with the shock positions in the manual has the chassis balanced very well when checking for spring balance. I also setup my sc10.2 about a year ago. I was able to get balance with the supplied springs, I just had to move the shock positions to balance it. Way to go AE.
Tim
Tim
#2082
Tim
Tim
#2083
#2084
The AE setups a couple of years ago, especially with the B44 cars, were downright terrible. Laughably bad. That speaks volumes for everyone else's setups as it won the previous Ifmar championship. When no one knows what they are doing, everyone is equal.
#2085
You should listen to the RIP episode with Cliff Lett. They talk about how they came up with the design for the RC10 stealth geometry Masami used in the 1991 Worlds. He very much gives the impression they had no clue what they were doing and just guessing until they came up with something that worked. And what they came up with was what they used going forward on their cars. I think that interview pretty much demonstrates the tuning knowledge they have.
