Serpent 811E Buggy Thread
#5149
In the 180 turns, I'm getting some mid-corner/exit push - basically when I'm starting to get back on power. Think I will increase my wheelbase from 1.25 to 2.5 in front of the rear hub. Is there anything else I can do other than running 14deg hubs? Currently running 12deg, 10-15-7 diffs. Thought about increasing the front to 12 or dropping the center to 12.
#5150
#5151
Normally this comes from the rear being too stiff. Weather the rear camberlink is too low on the tower, too stiff a spring, wheelbase too short, shock stood up too much, too much anti squat, to thick of oil. So moving the wheel base back is on the right track. I usually run it in the middle. #1 Ackerman also helps.
#5152
Is anyone using any shock o rings other than the stock o rings? I need to replace my o rings and am wondering if there are any better options than stock. Also, does the hard andonized chassis last longer than the stock chassis?
#5153
Thanks. I'm running #2 ackerman, middle inside on shk tower, orange v2 springs, 350 cst oil, shk outside on arm, position 2 on tower (almost laid down completely), 1 deg of anti-squat and 3 deg toe in. I'll start with the wheelbase. Then maybe the ackerman next? Or something else?
Stock. Someone mentioned the losi xrings work but I never tried them. Yes the hard chassis last longer until the coating wears off. Then they are the same.
#5155
#5158
Hey guys hope all is well in here! Would this motor fit the 811 E?
http://www.rcslot.com/Radio-Control/...yD9RoCrWrw_wcB
#5159
5Likes
