SC10 4x4 Thread
Trader Rating: 77 (100%+)
Yeah, the little ones holding the piston onto the the shock shaft. I've read of a few guys not doing it and having the screw let go, led to bent shafts and other broken parts.
Mine had 2 of the 4 loose.
Thought I'd post up some race results, all SC104's and 1 losi. Only one SC104 w/ garodiscs and 2 stage pistons though. I've given them all fair warning, they know what parts I use, they still don't see the light. Even after months of whoopn's. Some people will never learn..... Closest dude to me is a full 17 seconds back.... Once the RCSHOX center diff comes in, I'll put another lap on them...
2011 JCONCEPTS WINTER SHOOTOUT
Pro 4wd SCT open A Main Round# 3, Race# 7
________________________Driver___Car#____Laps____R aceTime____Fast Lap___Behind_
marc moody #1 18 5:07.960 16.215
travis baldwin #2 17 5:06.971 16.595
gary vanlanker #5 17 5:16.799 17.287 9.828
chad winfrey #3 17 5:16.869 16.538 9.898
jeremy feiss #4 17 5:17.496 16.689 10.525
james flagg #7 16 5:07.168 17.161
craig stoeltzing #8 14 5:20.853 18.456
chet ford #6 8 2:52.349 17.811
Scoring Software by www.RCScoringPro.com 11:04:47 PM 12/21/2011
Speaking of results, go on youtune and watch the jconcepts clash... watch the losi just contour to hack and bash his way by people... my personal favriot is on the last lap and the last corner he just blatenly true to take out the guy infringement of him... so pathetic...
I have no idea what you just said. "just blatently true"? "just contour to hack"?
I'm not being a dick, I don't think?
http://www.rinkworks.com/dialect/
Translates from English to Redneck, Jive, Cockney, Elmer Fudd, Swedish Chef, Moron, Pig Latin, or Hacker.
Try:
Well, really:
It's after Christmas. There are a ton of people who got this truck. The Thread isn't going to move forward for quite a while.
Let's just set up a table and sign setup sheets or something.
hopefully everyone had a good christmas and got all sorts of rc goodies, my family and fiance hooked it up fairly nice this year! currently stripping my truck down and rebuilding it, going to place an order for some new parts tomorrow with the christmas money i received!
time to get back to racing, been a few weeks actually.
LMFAO
I just installed a new Tekin RX8, and the fan was working, so I then plugged in the Hotwire, to check out all the adjustments on the PC, then when I plugged the battery in and turned on the ESC, I noticed the fan is not working now. Everything is brand new. What could cause the fan not to work? Or is it supposed to only come on when the ESC reach a certain temp.?
Also for the chassis brace, are you guys using carbon fiber tubing or aluminum? also how exactly are the rod ends connected to the brace? is there a set screw inside the rod end and into the tubing? What size parts are you guys using?
The fan only comes on during normal operation when the ESC hits 140*.
Brace using cf tubing and I used a long threaded rod through the tube. Go to your lhs and get the tube and fit the rod.
Mine is still in bags, inside the box. I'm going to continue to read before I build it.
So...I kind of screwed up. Step 1 in the kit building is the servo install. I thought my servo was centered. I was wrong. Even with the trim all the way, it's far from straight. Is there an "RCtech" shortcut to readjusting the servo, like page 707 has the rear diff removal guide?
I posted that to prove I've been reading. =D
Thanks in advance.
Thanks in advance.
