Like Tree5Likes
SC10 4x4 Thread
Old 07-07-2011 | 03:05 AM
  #4231
Eli's Avatar
Eli
Originally Posted by CentralCoaster
No no no.... not a band-aid. You have my assurance that it is a legitimate concern. Check your stock pads first though. It's a lackluster design pushing all that rear power through a single slipper pad. I think the main issue is that AE has a bunch of stoner dropouts engineering it's products getting paid in peanut-butter filled pretzels. Those guys took lots of engineering classes and may have even graduated but couldn't get real jobs so they are designing toy cars and doing a stellarly mediocre job at it.
wow dude, correct me if im wrong but didnt you win with your truck on its maiden voyage... i know thats not sating a lot after marshaling for the 4x4 amain tonight but it did get you to the finish first.
I think you may be the stoner drop out kevin just kidding man
Eli is offline
Old 07-07-2011 | 05:03 AM
  #4232
symmetricon's Avatar
Hey Salad, I know the 1410 has more powere but its killing my batteries, and while its smooth, it doesnt feel precise, meaning that the throttle imputs and the rpms dont feel conststently the same. Somethimes te same amount of throttle as the last lap is not enough to clear the big double smoothly. does this make sense? Like with my 1/8 scale, your finger memorizes o much throttle to give on each jump, too much and your overshooting, too little and your casing it.
symmetricon is offline
Old 07-07-2011 | 05:08 AM
  #4233
Could be the batteries and the voltage drop they have is more evident on the last laps.
raypa is offline
Old 07-07-2011 | 05:16 AM
  #4234
But this happens from the first lap to the second. i dunno, need sensored.
Old 07-07-2011 | 06:17 AM
  #4235
Its exactly because its sensorless. Reaction to throttle and brake inputs will not be consistent. I pulled out my 1410 and went back to my Tekin 550 motor due to this reason. Sensored will always be smoother and more consistent than sensorless.
Stealth_RT is offline
Old 07-07-2011 | 06:20 AM
  #4236
JFuel11's Avatar
As I stated previously, I feel AE has designed an incredible truck and I do nto agree with the above statement. It handles great, very durable and is capable of winning at any level. It is also hard for them to know how much power we would be strapping into these things. If you were only running a standard 2 pole 540 motor I don't think you would ever have much problems with the slipper. I run a 4.5 turn 550 motor and it creates to much heat with the stock slipper. I am sure they will do something to solve this issue as a Factory Team Upgrade but for now the clutch basket is a perfect solution. I am still very happy with the truck and no even more so. I can now put down the extra power that I have in the truck that I couldn't before.
JFuel11 is offline
Old 07-07-2011 | 06:24 AM
  #4237
JFuel11's Avatar
Default Sensorless
I ran my truck in a sensorless mode a few times myself and found that same issue to be true. The sensored setup is much smoother and throttle position always is the same until pack voltage starts to drop off. You need a pretty stought battery for this truck.
JFuel11 is offline
Old 07-07-2011 | 07:54 AM
  #4238
rcgod's Avatar
If you are using a tekin or castle esc the current limiting feature will help with that. I run my mmpro at 30% limiting and it feels as smooth as my ballistic 550. Without it it feels too aggressive and inconsistent. Running an external bec also helped out a lot. Mine cogged and did weird stuff without it.
rcgod is offline
Old 07-07-2011 | 08:16 AM
  #4239
Farmer_John's Avatar
I think y'all may be diagnosing the issue correctly, but applying the wrong cure.
I've noticed the same thing. Flipped the slipper pads and gone back out and problem solved.
Sensored guys, are you running pure sensored or smart sense (or whatever they call going from sensored at startup to unsensored once underway)?
If you're running in a hybrid mode, once you're rolling, sensored mode gets shut off...just saying....
Farmer_John is offline
Old 07-07-2011 | 08:34 AM
  #4240
Cain's Avatar
Tech Legend
so for the extra slipper pad you need to run the clutch basket setup, what is everyone going with? The HT pad or plain stock?
Cain is offline
Old 07-07-2011 | 08:40 AM
  #4241
Default Tuning Springs
Anyone know when we will see some springs availible for this thing? Or some that fit?
grubster is offline
Old 07-07-2011 | 08:48 AM
  #4242
OSherman's Avatar
underbody cover would be nice too.. ETA?
OSherman is offline
Old 07-07-2011 | 08:50 AM
  #4243
MadRussian's Avatar
Smile
Will have next week
MadRussian is offline
Old 07-07-2011 | 09:03 AM
  #4244
Cain's Avatar
Tech Legend
dumb question as the sc104x4 is still sitting in the box, does it include HT pads, if so how many?
Cain is offline
Old 07-07-2011 | 09:06 AM
  #4245
racer1812's Avatar
Super Moderator
No, they're not included. It comes with standard pads.
racer1812 is offline
