Like Tree5Likes
SC10 4x4 Thread
Old 10-02-2013 | 06:41 PM
  #35161
TommyJoe's Avatar
Unhappy
Originally Posted by fq06
That's true, wouldn't key in, it would ride on the balls.
You don't want to ride on your balls. Sitting on them hurts bad enough.
TommyJoe is offline
Old 10-02-2013 | 08:19 PM
  #35162
M03Racer's Avatar
Originally Posted by Wild Cherry
the shorty is lighter.
Drives great with the shorty.
jumps & landings are improved, accelerates better,can use a lower ride height for less chassis roll.
The saddle packs weight more.
Truck gains traction & stability.
Stick pack runs very smiliar to saddles except the trucks balance is not as good & steers a little less .
Thanks. I've been looking into getting some shorties. But why is there only 4600mAh and no bigger. Also what would I need to convert to shorty packs. To hold down the battery.
M03Racer is offline
Old 10-02-2013 | 09:24 PM
  #35163
Wild Cherry's Avatar
Tech Legend
M03
Can use the team saddle pack tray and run the shorty centered on the chassis .
Just place foam blocks on each side of the shorty to help secure ...
Already using stick packs ?
Mount the shorty all the way forward in tray & place foam blocks behind the battery to help secure .
Wild Cherry is offline
Old 10-03-2013 | 12:34 AM
  #35164
If you won't a setup the can win with out being a perfict dive for 1/8 track pm me
9turn is offline
Old 10-03-2013 | 12:37 AM
  #35165
Shark413's Avatar
I have been running a shorty up front since March and with the shorty the balance is so much better. Like many, I tried to make my SC10 4x4 something it was not. I added a bunch of weight, Exotek chassis, lead weight, saddles, etc. Tried to make it into a Losi/Tekno but I found it didn't work as well as the other trucks. I tested an AE Prolite and was impressed with how light it was (but it did not have the same build quality as the SC10 4x4). I then looked at my SC10 4x4 and decided to go the other direction and make it as light as possible. Using a shorty pack would save a ton of weight and it is really an easy modification, I took the stock stick pack battery bracket and basically turned it 90 degrees, drilled one extra hole to hold it in the new location. For a hold down I used the stock holes where the nerf bars attach (front holes) I threaded a M3 set screw into the hole and use some thumbscrews to hold a battery strap down. My strap is carbon fiber but I could have easily used a piece of plastic or aluminum. My SC10 4x4 weights in at 5lbs 5.4oz with a shorty pack and some other mods. Before the shorty mod and the cDiff ny SC10 4x4 just sat on the shelve, and my Durango and Tekno got all the track time. Now I only run the SC10 4x4, the Durango is gone and the Tekno is my backup.
Shorty pack mounted in my SC10 4x4.
I used a scrap piece of CF for a battery hold down.
Two thumbscrews hold the strap down.
5lbs 5.4oz (includes 28grams of lead weight up front) This picture shows it with a VTS slipper that I was testing. I have been using the RCShox cDiff since the middle of 2012 and it is far superior to anything else I have come across (clutch basket, Pinned slipper, VTS).
cDiff
Shark413 is offline
Old 10-03-2013 | 05:59 AM
  #35166
M03Racer's Avatar
[QUOTE=Shark413;12599512]I have been running a shorty up front since March and with the shorty the balance is so much better. Like many, I tried to make my SC10 4x4 something it was not. I added a bunch of weight, Exotek chassis, lead weight, saddles, etc. Tried to make it into a Losi/Tekno but I found it didn't work as well as the other trucks. I tested an AE Prolite and was impressed with how light it was (but it did not have the same build quality as the SC10 4x4). I then looked at my SC10 4x4 and decided to go the other direction and make it as light as possible. Using a shorty pack would save a ton of weight and it is really an easy modification, I took the stock stick pack battery bracket and basically turned it 90 degrees, drilled one extra hole to hold it in the new location. For a hold down I used the stock holes where the nerf bars attach (front holes) I threaded a M3 set screw into the hole and use some thumbscrews to hold a battery strap down. My strap is carbon fiber but I could have easily used a piece of plastic or aluminum. My SC10 4x4 weights in at 5lbs 5.4oz with a shorty pack and some other mods. Before the shorty mod and the cDiff ny SC10 4x4 just sat on the shelve, and my Durango and Tekno got all the track time. Now I only run the SC10 4x4, the Durango is gone and the Tekno is my backup.
Yeah I got the AE ProLite also and fund it to be good but not as good as the SC10 4x4 since its an entry level truck. I will not be able to run my SC10 4x4 this year but I wanna have it set up for next years season. I will finish the season with my back up truck a Team C TS4.
M03Racer is offline
Old 10-03-2013 | 09:13 AM
  #35167
Tech Legend
Not sure bout next year's season , think Ae has plans of their own for the Sc10 4x4....
Old 10-03-2013 | 10:36 AM
  #35168
louielou's Avatar
Default RCX center diff
Does anyone know where i could pickup an RCX center Diff?
louielou is offline
Old 10-03-2013 | 11:41 AM
  #35169
Cain's Avatar
Tech Legend
out of stock from RC Shox I take it.
You could try the boards, I see them pop up once in a while, sometimes with a vehicle for a good price.
Cain is offline
Old 10-03-2013 | 11:48 AM
  #35170
Redwings's Avatar
So with that being said. Should i hold off on buying on until next year?
Redwings is offline
Old 10-03-2013 | 11:52 AM
  #35171
Tech Legend
Only if your not interested in having fun , waiting sucks ....
get your Sc 10 4x4 now ...
Could be many months from now before some thing new comes or next month , only Ae knows .
Old 10-03-2013 | 01:18 PM
  #35172
fq06's Avatar
Marcus has probably sold out with all of the advertising WC has done for him over the past few days
He may just be waiting on spurs to machine or something like that. Contact him on the RcShox thread here on RcTech or through his site and ask when they are expected to be back in stock.
http://www.rctech.net/forum/electric...-services.html
http://www.rcshox.com/sc1044-center-dif-v2/
fq06 is offline
Old 10-03-2013 | 01:33 PM
  #35173
Cain's Avatar
Tech Legend
lol
Cain is offline
Old 10-03-2013 | 01:35 PM
  #35174
Tech Legend
Have nothing to do with ,
nor have I recommended to anyone ever ....
Old 10-03-2013 | 01:39 PM
  #35175
Cain's Avatar
Tech Legend
I thought you said you new what worked and have tested everything?
Cain is offline
