SC10 4x4 Thread
#3497
re: traction rolling.
If you move your top shock mount on the rear to the outer hole (stand them upright) it will make it stiffer into the corners.
and probably putting some spaces under the inner ballstud on the rear would work also.
try the shock one out. it worked for me, Using 30w all round.
#3498
Before making swaybars, I laid the rear shocks down and it reduced the rear washout. I run on a large track with large fast sweeping turns and swaybars are a must. On a tight smaller track I can run with out the bars.
#3499
How do you know how many washers/spacers to put on the ballstuds?
I understand it will change the roll center.
How many washers would I need for a loamy / bumpy surface?
Anyone have pics of the washers on their ride? I'm a visual person.
#3501
Just start adding them and drive. When your truck starts behaving itself, you're there.
I thought the sway bars were going to be the answer, but adding them was only part of the solution (the solution that I"m still working on. Lord help me when I run this thing somewhere else...).
#3502
Ummm yeah. These tires have holes in them.
I used my display tires at an event where I needed them not expecting too much dirt ingestion. That is why I posted this. These were ruined in one race night. I just don't want others to run into the same problem with stock wheels.
#3504
The thing to remember and what you're trying to accomplish is reducing body roll. Lowering the roll center helps this along.
So do you use them for both the front and rear ballstuds?
#3505
No and you are right they are not ruined. But there is a vast majority of guys out there that don't do well with gluing clean tires let alone trying to clean them out and re-glue them.
My post was merely a surprise to me that there was that much dirt in them after only 15 minutes of race time on a wet track. Mostly due to the two 6mm holes in the rim as well as the glue holes in the inner face of the wheel. When Mark (Pavidis) created those holes in the first place for the AKA wheels our initial testing showed way too much dust intruding into the tire. So he had the mold updated to skin those holes over for those that would not use them or know what they were for. They are still there on the AKA wheels you just need to slightly poke them open to use them.
#3506
Great post on your behalf
#3509
D
#3510
Look at the 3 screws tht hold the plastic shroud around clicker if its screwed in too much it will rub on the clicker and you'll have some binding issues, I've helped out many with their sc10's at wcrc all the way to sdrc and I've built about 8 of these trucks and each has it's own different flaws. Just be sure that you double check the screws and you'll easily find small simple stuff that can cause an issue. Hope this helps
D
D
5Likes
