Like Tree5Likes
SC10 4x4 Thread
Old 02-13-2013 | 08:55 PM
  #32656
Wild Cherry's Avatar
Tech Legend
Run the 20T front & rear ...
Truck will be easier to drive and more consistent...
Wild Cherry is offline
Old 02-13-2013 | 09:01 PM
  #32657
Originally Posted by Titian2010
Ok another question, trying to figure out the difference from the rtr, kit and FT model. My truck came with front and rear sway along with the rear tower that can house the body post. My truck has the silver sway bar that only goes from the front gearbox to the rear. The brace doesn't reach the rear tower like the ones when I search FT pics. Also how can i tell if i have the updated belt cover before i buy another? What am I working with?
not sure of the rtr/// but if your shock are blue and you only have one pad on the outer slipper/no chassis brace. you have the non FT
gatorage is offline
Old 02-13-2013 | 09:22 PM
  #32658
Titian2010's Avatar
Must be a non FT with minor upgrades. Has two pads because I just installed them new but blue shock bodies. Thanks I don't know how I missed the color shocks. Was on amain comparing pics and didnt notice.
Do you guys recommend I get the updated vts system or high torque pads? I'm using the ballistic 4.5 with mmp. I'm not racing it. Its just for track fun during down time.
Titian2010 is offline
Old 02-13-2013 | 11:28 PM
  #32659
Don't wast the time get the center diff and use the motor limiter to stop wheel spin
9turn is offline
Old 02-13-2013 | 11:33 PM
  #32660
Dose any one have some ft shocks they to sell or trade I have to stage pistons in the stockers pm me
9turn is offline
Old 02-14-2013 | 09:45 AM
  #32661
Tech Legend
The VTS has been proving itself with results like last week ends Sc Show Down Tour in Tacoma .
I highly recommend using .
Use the HD pad behind the spur gear and the VTS basket & pads ..
Brings more traction , less wheel spin ....
Old 02-14-2013 | 12:06 PM
  #32662
Titian2010's Avatar
Right on. Its only a few bucks so ill give it a shot.
When you say center diff you mean the vts correct? Sorry I'm still learning the truck so I'm lost with some things. When you say center I picture the center diffs on my 8 scale stuff. Didnt know my truck had a center diff so yeah newbie in this class.
But thanks all for answering my questions. I've been around with different cars and sometimes guys just point or say read back to day one which I'm doing but thanks
Old 02-14-2013 | 12:14 PM
  #32663
No there's a bald available for this truck the one with the pins in it works the best
9turn is offline
Old 02-14-2013 | 12:22 PM
  #32664
Cain's Avatar
Tech Legend
he is talking about the RC Shox Center Diff. Excellent item. Its a ball diff that has pins you can insert behind the balls (or to the side depending on how you view it) that you can adjust the diff action. in general 4 pins is where you start, I liked 8 pins on carpet, excellent diff action still be loads of power.
Cain is offline
Old 02-14-2013 | 12:23 PM
  #32665
Mechintosh's Avatar
Looking to go outdoor racing with the 4x4. Looking at the LRP 4.5t and the Reedy 4.0. Racing on mostly hardpack, some clay. Local racers using anywhere between the 4.0t and a 5.5t. Should I go with the HP of the 4.0t or the 4.5t. Coming from a RTR setup that has been upgraded with the FT kit and sway bars. I have run mostly indoors where HP does not really come into play. Thoughts?
Mechintosh is offline
Old 02-14-2013 | 12:28 PM
  #32666
Tech Legend
The Sonic 550 4.5 will have plenty of speed and will be smoother then a 4.0....
A lot of the faster racers around my area use the Reedy 550
Old 02-14-2013 | 12:33 PM
  #32667
ButtDyno's Avatar
Got a quick question!
Running a sc10 4x4 on a indoor track clay. What would you recommend for esc/motor combo along with lipo. I got a old Vector X11 8.5t with a Sxx V2 tc sitting around would that be good to get her rolling?
Thanks-
ButtDyno is offline
Old 02-14-2013 | 12:37 PM
  #32668
Tech Legend
Thanks-
The ESC is great , make sure to use the fan and it will come in kool .
The 8.5 will work but will be slow , suggest more power .
Old 02-14-2013 | 12:47 PM
  #32669
ButtDyno's Avatar
Don't like slow...what would you suggest? Maybe a 5.5 to 6.5?
Thanks-
ButtDyno is offline
Old 02-14-2013 | 12:51 PM
  #32670
Tech Legend
Thanks-
Maybe a 5.0 550 Sonic or even faster ...
A 4.5 is just right on the tracks I race on....
