Like Tree5Likes
SC10 4x4 Thread
Old 10-07-2012 | 12:35 AM
  #30181
Wild Cherry's Avatar
Tech Legend
Originally Posted by Chernobyl23
When running the 8mm mod,what combo of sway bars are being used? Medium to high traction indoor clay track
to start with yellow ft bar & blue rear ...
there are other sets -ups on www.rc10 that use lighter bars .
Suggest you check out all of the team set -ups posted there for the Sc10 4x4.
Wild Cherry is offline
Old 10-07-2012 | 04:54 AM
  #30182
Acill's Avatar
Im going to pick up a set of those M2C blocks when they get back in stock. Whats a good point to start with on a medium indoor track? Its tight and fast.
Acill is offline
Old 10-07-2012 | 05:55 AM
  #30183
I hope my loved ones slap me when I am a crotchety, stubborn, pig-headed, know-it-all like WC. Guy just can't get it through thick head that some things are preferred and better for different racers.
bohdi is offline
Old 10-07-2012 | 06:37 AM
  #30184
fq06's Avatar
Stock anti squat, 1/2 degree offset. If you have too much push or your rear end feels too locked in, try the 1/4 degree offset.
fq06 is offline
Old 10-07-2012 | 07:26 AM
  #30185
Pointy71's Avatar
After reading a bit on forums and in magazines I decided for the SC10 4x4 FT over the Losi SCTE. Because I mostly run AE and love the handling of all of them. Also because it was mentioned the AE is more "aggressive" and better handling on smaller technical tracks.
Well, not so sure anymore. My SC10 is 100% stock (always a good starting point). And very fast, that's not the problem...
First of all it is making noise (cracking). First thought it was the clicker but I closed it and it is under power and not while braking. It's also not a "clicker sound". It must be a gear box... As mentioned; the car is 100% stock. Can't remember adding shims and just checked the manual; also no mention of them. Is there a common issue with the gearboxes? Hopefully with a common solution?
My biggest problem however is that it doesn't handle very well. My B44.1 is sooooo easy to drive fast. This SC10 twitches, the back comes out all the time and basically it slides all over the place. Any advice? Don't feel like reading 2,013 pages... Hope you forgive me.
And to make it even worse; my friend decided for the SCTE and let me have a go; very smooth and very easy to drive without any tuning.... That pissed me off. I have read the AE is more difficult to go fast with but this much difference I did not expect.
It's a beautiful car and I love AE but so far I'm disappointed. Spent so much money to build a nice truck and now this
I dry on an outdoor medium traction clay track which is quite short and technical.
Any ideas what I should change to make it more stable?
Pointy71 is offline
Old 10-07-2012 | 07:35 AM
  #30186
fq06's Avatar
Long list I guess, others will add to it...
Did you limit the shocks up travel with 4mm to 5mm of supplied shaft clips? If not, the cva is contacting the outdrive and flexing the sun gear shim allowing too loose of a gear mesh... slipping or "clicking" diff gears. Probably need to replace rear gear set. Fresh rear gear set will take one stock (0.2mm) shim up to two. Front worn gear set may want two or even the 0.5mm that AE will mail to you.
Front & rear belt adjustment tight enough? Tightened after break in?
What are your diff oil weights? Sounds like you need to go thicker in the front or lighter in the rear or both.
Cain's review of adding more rear toe in, may be what your looking for...
http://www.rcshortcourse.com/forum/t...e-setting.html
What tires are you running?
There was a question about what to get to improve the truck a few pages back, some good comments there.
You will spend money on this truck to make it keep up with the Losi and your friend will spend money on his Losi to make the drivetrain and a few weak spots on the truck as durable as the AE.
Try starting with a AE pro setup sheet from their site that matches your track and tune to your preference from there.
http://www.teamassociated.com/setupsheets/SC10_4x4/
fq06 is offline
Old 10-07-2012 | 08:04 AM
  #30187
Smittydidit's Avatar
Originally Posted by JEFFs SC10
Well guys I did something today totally unexpected. I traded my truck away.
I got a fantastic deal on a brand new Losi that will get the MIP kit put on it.
I'm excited as I heard this truck will be a lot easier to drive especially where I'll be running is primarily outdoor.
Hey Jeff,Congrats!. I spent yesterday at West Coast raceway here in So Cal and I know was running smoother and faster with less effort with my MIP-Losi. I hope you enjoy yours as much as I am mine!
Mark Smith
Smittydidit is offline
Old 10-07-2012 | 08:20 AM
  #30188
Originally Posted by fq06
Right on, should be there hour or so after the opening bell. Won't hold you liable for me spending money on a new kit... but my wife might
FQ. Missed you yesterday!. Was looking foward to some fast laps with ya!.
Maybe next time
Mark Smith
Old 10-07-2012 | 08:22 AM
  #30189
fq06's Avatar
Maybe next time
Mark Smith
I know, sucked... couldn't get out if here yesterday and the wife has a few fun activities planned for today. No driving this weekend and I just refreshed two cars that I'm dying to drive
fq06 is offline
Old 10-07-2012 | 09:39 AM
  #30190
vito's Avatar
ok whats the top speed of the a novak 550 4.5 trun? mid 30
vito is offline
Old 10-07-2012 | 09:59 AM
  #30191
ABN Hoosier's Avatar
Default question
I recently noticed after a few runs the rear shock cartridge cap on the bottom of the cap was cracked and lost all the shock oil.
Here is the part I am talking about in this picture shown by the red arrow.
My question is. I am not sure why or how it cracked. I know I have read to run the shock compression limiters "c clips". Not sure if this is related or not. I was running one (2) c clip on all the shocks. How many are you guys running? Also, I am running the RC Shox dual stage pistons. Any developments on any new shock findings?
Thanks...
ABN Hoosier is offline
Old 10-07-2012 | 10:03 AM
  #30192
Tech Legend
Hoosier , taking a guess here ..
Perhaps it cracked from being tighten down to far ?
I know , its a bad guess..
give me another cup of joe please...
Old 10-07-2012 | 10:08 AM
  #30193
tlb987's Avatar
Originally Posted by Krio
Nothing wrong with the 32 pitch on a 540 motor. The larger pitch is a touch less efficient, so if you start having temp problems to down to the 48 pitch.
Thank you for the advice!!
tlb987 is offline
Old 10-07-2012 | 10:19 AM
  #30194
Cain's Avatar
Tech Legend
+1 one. heck, depending on how the rear end feels, I am thinking of trying less than stock 3 degrees since its very night with 180s.
What setup are you using exactly? Is this a factory team kit setup or the RTR / plain kit setup? To be honest, AE out of the box setups in general I felt were lacking. There posted team driver setups though usually are money.
Cain is offline
Old 10-07-2012 | 10:20 AM
  #30195
probably so. I thought it might have to do with the RC shox pistons being thicker and maybe causing issues and maybe the clips too.
