Like Tree5Likes
SC10 4x4 Thread
Old 04-23-2012 | 11:54 AM
  #22051
RichyRich's Avatar
Originally Posted by MantisWorx
Its all good, I have been screwed myself on more than one occasion. Unfortunately just like the V1 dif they are rarely ever "in stock" i just cant make enough at one time mainly because i can only get a certain amount of AE spur gears at any given time. It took me a month to gather enough for the pre-orders! so my suggestion is to order ASAP and get in line otherwise its unlikely that you will order and it will ship on the same day UNLESS you order this week because i will have a few extra's.
FYI my website is run through Paypal direct so you are protected against any kind of CC fraud.
Ordered this morning... Thanks!!!
RichyRich is offline
Old 04-23-2012 | 01:29 PM
  #22052
Evil Genius jr.'s Avatar
Originally Posted by Krio
If someone is just looking for a couple parts off the FT 4x4, I have several left from the kit I'm parting out at kriostasis.com/store.
Do you run that site? Has very good prices, next time I need something I'll look there first.
Evil Genius jr. is offline
Old 04-23-2012 | 01:45 PM
  #22053
Cain's Avatar
Tech Legend
I got some stuff on the way from him, should be here soon. Very fast shipping and good prices for the stuff.
Cain is offline
Old 04-23-2012 | 02:05 PM
  #22054
drolmaeye's Avatar
Originally Posted by CraigMBA
These are 540's, but the endbell is the same on the 550's. Notice the notch in the Ballistic endbell compared to the HV (which doesn't have it). The Novak Ballistic 550 fits without grinding in case anybody cares.
Yes, I care. Saw the video of grinding the chassis and decided I would not get a Novak 550 for my soon-to-be-purchased sc104x4. I contacted Novak customer service and the guy told me once you get it in, the 550 can will mount and accommodate proper mesh without chassis contact. Still, I wanted confirmation from someone who used one. Thanks for this.
drolmaeye is offline
Old 04-23-2012 | 02:06 PM
  #22055
So If I have the outside raised 8mm and I add 3mm of spacing to the inside will it handle like 5mm on the outside?
Old 04-23-2012 | 03:17 PM
  #22056
JEFFs SC10's Avatar
Why not just add 5 on the outside and call it a day?
JEFFs SC10 is offline
Old 04-23-2012 | 03:48 PM
  #22057
Because that's not what I want, I am just wondering the relation between inside and outside adjustments.
Old 04-23-2012 | 03:49 PM
  #22058
Mizchief's Avatar
Originally Posted by Gon3r
Can the Spektrum Telemetry take both measurements at the same time (i.e. run another temp through the Aux or something)?
I'll can move the thermo to the ESC, but was concerned taping the temp on would hinder heat sink and give false reading. I have an IR Thermo, so can try that.
Not that I know of, I would just use the IR gun. I'm only using the temp sensor in my 17.5 SCT since that motor is usually close to the edge.
Mizchief is offline
Old 04-23-2012 | 03:54 PM
  #22059
Mizchief's Avatar
http://youtu.be/tFI5Sv9Y2c0
Mizchief is offline
Old 04-23-2012 | 03:58 PM
  #22060
fq06's Avatar
Me too, I was wondering what the inside and outside do together.
So if I put 3 on the inside and 8 on the outside, is it the same as 5 on the outside and stock height on the inside? Or will it handle differently even though I would think that the angle would be the same. Maybe it does differ throughout the suspension stroke?
I think I just got a headache from that
Edit: would net +3 on the inside be the same as net +3 on the outside?
fq06 is offline
Old 04-23-2012 | 04:18 PM
  #22061
net +3 on outside = net -3 on inside
Old 04-23-2012 | 04:21 PM
  #22062
Redxz's Avatar
Have a NIB FT VTS slipper conversion (91175), and NIB HT pads I would make someone a heck of a deal on. Price for everything including shipping= to what VTS goes for kind of a deal.
Redxz is offline
Old 04-23-2012 | 04:30 PM
  #22063
fq06's Avatar
So if outside height is stock and I went to the outer hole on the chassis and the inner hole on the hub shortening the rod (or one of the two)... wouldn't that have the same effect?
Lowering the ballstud height on the chassis would take away chassis roll and reduce traction?
fq06 is offline
Old 04-23-2012 | 04:37 PM
  #22064
IRM616's Avatar
I GOT MY DIFF UPGRADE V2 BUT HAD SOMEQUESTION ON THE INSTALL.
HOW TIGHT DO I MAKE THE NUT? AND ANOTHER TIPS? WHATS THE LIL BLUE WASHER FOR? THANKS
IRM616 is offline
Old 04-23-2012 | 04:42 PM
  #22065
Blue washer goes first on the shaft. See Cams install post.
