Like Tree5Likes
SC10 4x4 Thread
Old 05-24-2011 | 03:12 AM
  #2011
murky123's Avatar
Originally Posted by w00kie
FFS mate, stop talking about yourself in third person. Your not 4 years old, stop acting like it.
Moreover, it is very annoying to read texts written in third person.
Especially when they talk about themselves
murky123 is offline
Old 05-24-2011 | 03:23 AM
  #2012
ffpm46's Avatar
Has anyone figured out the shock o rings to replace the X-Rings?
ffpm46 is offline
Old 05-24-2011 | 03:56 AM
  #2013
rcracenut's Avatar
The manual doesnt say anything about lube for the slipper thrust bearing. I would assume a thin layer of the black lube. Is that what most are doing?
rcracenut is offline
Old 05-24-2011 | 04:07 AM
  #2014
Matt Howard's Avatar
Originally Posted by RodneyB
For what it's worth, my LHS called the distributor to check on the sway bar back orders while I was there earlier this evening. They said "we don't have a date".
thanks, kinda what I figured
Matt Howard is offline
Old 05-24-2011 | 04:44 AM
  #2015
Mongoose76's Avatar
will these bladders work on our 4x4'shttp://www.amainhobbies.com/product_...cone-Bladder-4
Mongoose76 is offline
Old 05-24-2011 | 04:47 AM
  #2016
Gabriel2010's Avatar
Default Sway bars
Did anyone find out how to build the sway bars ? What rod to use ?
Gabriel2010 is offline
Old 05-24-2011 | 05:08 AM
  #2017
murky123's Avatar
I use 2mm pianowire and some hardware from my spare parts box.
there are some pics in this tread about home made swaybars
It is easy and not more then 15 minutes of work fabbing up your swaybars
murky123 is offline
Old 05-24-2011 | 05:21 AM
  #2018
symmetricon's Avatar
Originally Posted by spiro
Are the diffs on this beauty the same as in the SC10? ( 9827 ) This:
http://www.amainhobbies.com/product_...r-Differential
Edit:
Just realised that the manual states this in spare parts for diff: 91008 - 4x4 Gear Diff Kit. Guess that means different diffs. Still interested if anyone knows this for sure though.
The big difference is the main diff gear itself, the 4x4 uses 32p, while the 2wd used 48p.
symmetricon is offline
Old 05-24-2011 | 06:41 AM
  #2019
slakr's Avatar
Can somebody please help with a starting point for gearing with the Castle 1410/MMP?
Thinking 48P 93T spur http://www.amainhobbies.com/product_...-Spur-Gear-93T
With 16T pinion http://www.amainhobbies.com/product_...inion-Gear-16T
This is the track I usually run on http://www.youtube.com/watch?v=7RfS54nuL3s
Thanks.
slakr is offline
Old 05-24-2011 | 06:52 AM
  #2020
Vegatron75's Avatar
Do any of you guys think that the stock settings for the servo saver are way to tight?
FYI, If your radio doesn't have EPA adjustment, you'll have to get a radio that does. I had been making the traxxas link radio work up until I got this truck, ended up stripping the servo horn. I've since bought a airtronics radio.
Vegatron75 is offline
Old 05-24-2011 | 06:59 AM
  #2021
JEFFs SC10's Avatar
I dont know about ya'll but I can't ballpark a truck's spur/pinion gearing by viewing a youtube video.
get out there run a few laps and temp your motor, if its hot gear up, its not that hot gear down.
just saying.
JEFFs SC10 is offline
Old 05-24-2011 | 07:13 AM
  #2022
McKleroy's Avatar
Thanks.
Im running a 15/93 and it is a little slow, motor temps are in the 160 range after three straight packs with no breaks, im thinking of trying about a 17-20 range. 16 is a good starting point.
McKleroy is offline
Old 05-24-2011 | 07:18 AM
  #2023
McKleroy's Avatar
Default tires
What about tires. What is the best bet for a loose dusty track. On my 2wd goosebumps rear/ bow tie fronts work really well. I've had calibers on all 4 corners and not happy with them. Do you want the high traction tires on the front or what? Im thinking bow ties which have no sidebite and great forward bite on the front and goosebumps to stick the rear, like the 2wd. Im getting a push right now and alot of traction roll, but it can still spin out like too much front traction. Other options would be subcultures. I am going to try the other front pulley.
McKleroy is offline
Old 05-24-2011 | 07:25 AM
  #2024
slakr's Avatar
@McKleroy – thanks for the input I’ll start with the 16 and report back where I go from there.
@Jeffs SC10 –
slakr is offline
Old 05-24-2011 | 07:37 AM
  #2025
Snipers do well, good forward bite, and not to much side bite, if you worried about traction rolling. I run on a dry dusty track with some loam in some corners. Also, swaybars help alot.
