Like Tree5Likes
SC10 4x4 Thread
Old 05-22-2011 | 08:02 AM
  #1831
1Fastpede's Avatar
Need some help. My slipper is slipping when fully locked with high torque pad frt and rear. Also slipper temp was 167 after 6 min main......... no binding/ belt is great (not tight) its all slipper on a 550 4.5
1Fastpede is offline
Old 05-22-2011 | 08:47 AM
  #1832
Originally Posted by T-BirdJunkie
Hey...recommendations on batteries? Don't care if it's a $20 cheapie from HK or a $150 Thunder Power pack...ThunderbirdJunkie needs a good battery or two for this truck since it's a lot heavier duty than his other 1/10 2 cell stuff and taxed the Venom 30c 5000 and the Turnigy 5000 20c that he ran pretty heavily, it seemed.
MaxAmps Race Edition 150c 6500 mah. Awesome pack... Pricey, but awesome.
Lon_L is offline
Old 05-22-2011 | 08:50 AM
  #1833
05PSD's Avatar
Originally Posted by OhGetSick
Have any of you that run on loose tracks try the 19T overdrive clicker yet? I tried it for about two laps before I broke the front right knuckle, but from what I could tell it really helped exiting the corners on power and full throttle down the straight without the rear sliding out….
I would add Front Steering-Caster Blocks #91026 to your list of extra parts if you haven’t already.
I broke the same part. Local shop has them on order. Luckily mine is still usable as it isnt as destroyed as yours.
05PSD is offline
Old 05-22-2011 | 08:57 AM
  #1834
BlueGlowBoy's Avatar
Default Break in and (hopefully) no binding?
I just put my truck through it's first pack... ran it on the street to get minimal bounce into the suspension, just trying to work things in and find any major issues before I start abusing it on the track. Running a Tamiya 540 silver can with a 14t pinion, again, to take it easy on the truck.
I estimate the top speed around 15mph (scriptassylum tells me 17mph, but the silver can was definatley struggling to get the truck up to speed) and when I let off the throttle, the truck still coasts 50-60 feet. The ESC never got above ambient, but I attribute that to running a silver can...
I remember someone saying that if you can give the truck a gentle push, it should coast 10-15 feet, but "gentle" is so subjective....
Is a 50 foot coast with no throttle from 15mph reasonable? I am trying to keep this truck as efficient as possible....
BlueGlowBoy is offline
Old 05-22-2011 | 09:07 AM
  #1835
Wild Cherry's Avatar
Tech Legend
Originally Posted by FrancoisTX
There is a big difference between myntruck and yours, I have a CC 3800 kv motor and you a big 550. A big difference of weight at the rear, mybe that or belt to tight.
Use the kit suggestion for the belt tensioner settings for the belt.
Doubt the belt tension & motor motor weight is the issue..
Check that ride height , check shock oil level .
Make sure drive train is free, nothing blinding..
Rest is driving technique....
Wild Cherry is offline
Old 05-22-2011 | 09:14 AM
  #1836
Well here it is. My first race with the sc10 was at Area54 in Ohio and I qualified second and finished first and guess who the tq was??? Mister Ryan Lutz. It was so cool just being in a race with him. He is a very cool down to earth guy. I was so excited when I passed him for the lead that I couldn't believe myself, until I found out that he was having issues and had to drive half speed for half the race. He is awesome to watch drive and makes it look so easy and effortless. I did not break a single part all weekend and once I figured out how to drive it the truck was great. It's very durable. I will frame my picture with me standing on the podium (1st place) next to Ryan(2nd place) because I am sure it will never happen again but hey a win is a win
JoeC is offline
Old 05-22-2011 | 09:25 AM
  #1837
On the slipper issue if you have one that will not tighten all the way I had to add 2 thin washers after the silver thrust washer because it was not machined right. Works like a charm now.
JoeC is offline
Old 05-22-2011 | 09:39 AM
  #1838
ilanstylz's Avatar
Well off to my local track with my sc10 4x4 for the first time, I'll be running my mmp esc and 3800kv 1410 motor setup, with gold barcodes all around.... Gonna try it with and without swaybars (from scte), and with/wout clicker........ Gonna take vids and post my experience when I get back, can't wait!!!!!!!!!!!!!
ilanstylz is offline
Old 05-22-2011 | 10:13 AM
  #1839
CRCDUDE's Avatar
LOL Thats totally awesome Joe .. Congrats. Did ya ask him to autograph yer trophy ?? Haha. Wish i coulda been there with you guys
CRCDUDE is offline
Old 05-22-2011 | 10:24 AM
  #1840
CRCDUDE's Avatar
For those searching for more knowledge. I am currently running a Tekin 4.5 w/ a Rs Pro. I added a 5800 Uf capacitor (aka novak glitch buster) to the battery side and this helped lower temps
On the uber hi traction we currently have at Raceworld Raceway (slicks/wheelies) my temps are under 160 after 8min main and 4 lights on the esc.
I did notice that the 550 motor seems to "heat soak" more and either requires a fan to cool off between rounds or lots of time.
CRCDUDE is offline
Old 05-22-2011 | 10:34 AM
  #1841
TEAM-AE-4-EVER's Avatar
Well, I was asking for info on the last page... Thanks for sharing...
Any know parts i should stock up on in order to hopefully avoid wasting a race day? Again, what are some advantages/disadvantages when comparing a 550 motor and a 540 motor for the kit? I run on larger outdoor tracks that accommodate both Truggy and 8th Scale buggies... Thanks guys!
TEAM-AE-4-EVER is offline
Old 05-22-2011 | 10:50 AM
  #1842
HarleyGuy's Avatar
Ran my SC10 4x4 yesterday for the first time... Had it set with the 19T clicker RX8 and the sc4x 550 5.5T with 5K in the front and rear diffs. The truck soaked up the whoops section great and jumped great, but I had a couple of issues that I was hoping someone here could help me with... First, the track was hard pack but very dusty so it was slick (I was running Super-soft Calibers) and in the turns the truck had a tendency to spinout... Tendency would kind of be an understatement, if I wasn't perfect it spun (is this a product of the clicker?)
Secondly, I aligned my servo (Savox SC-1256TG) during building, but as I was driving I noticed that my truck kept pulling to the right... I would adjust the trim and it would be good for a few minutes then start pulling again... In the end I had the trim set 100% to the right... Anyone had an issue like this??? If so what was the cause?
Thanks for the help,
Shane
HarleyGuy is offline
Old 05-22-2011 | 11:47 AM
  #1843
Look at Jangs review of the MaxAmps. The $35 Gens Ace did better.
http://www.ultimaterc.com/forums/sho...d.php?t=124746
Jedev is offline
Old 05-22-2011 | 12:57 PM
  #1844
HarleyGuy's Avatar
I run the Gens Ace and love them... The only issue is finding them in stock.
Old 05-22-2011 | 01:00 PM
  #1845
I have had them all and for the money the Gens Ace is by far the best!!
JoeC is offline
