Like Tree5Likes
SC10 4x4 Thread
Old 01-25-2012 | 09:19 PM
  #15811
CraigMBA's Avatar
Originally Posted by heavyjeffd
My truck is doing wheelies on carpet, is this normal?
Every one I've ever seen did that out of the box.
If I need to loosen up the slipper I can, but as it is there's only one thread showing.
If you slip it enough where it won't wheelie, it's so loose and builds so much heat it will start to fade after 2 or 3 minutes, and then you will likely have trouble jumping anything.
Welcome to the party!
CraigMBA is offline
Old 01-25-2012 | 09:22 PM
  #15812
CoyoteSlash's Avatar
Originally Posted by MantisWorx
just take a deep breath and let it go!!
I 'was' trying to help. Like the guys are saying, there's some stubborn going on.
I'll chill.
Originally Posted by Cain
roylo: Just a question, have you tried the chassis brace at all to see if it does fix your issue?
He hasn't, and won't. Because it's a problem with "all" of our trucks. (even though it isn't.)
...I don't even know how to help now without being a butthole. I really do wish you luck, Rylo. Call AE and you can argue with them about it. They will send you some replacement parts which are the same exact part, but not 'broken' like we've been trying to help you with. Replace a couple parts and you'll see why you're getting these responses.
This Thread Promises.
CoyoteSlash is offline
Old 01-25-2012 | 09:23 PM
  #15813
Keep it tight, and put some Expo in your throttle, Or learn really quick some feather throttle control
Old 01-25-2012 | 09:27 PM
  #15814
Default Clutch basket / top shaft issues
Hi guys, *I was previously using high torque pads from a 2wd I think, the smaller ones. Those were black and glossy. So, I decided to change the pads w the sc10 4x4 pads.
Now, I've installed the wider pads and there seems to be no adjustability when I put everything together w the nut flush like before w no issues. feels like all four wheels are binding now and I've replaced two rear top shafts due to stripping the treading because of trying to figure out WTF is wrong. I'm using three pads total. *Anyone have this issue? Sooo frustraded..
danielXIII is offline
Old 01-25-2012 | 09:35 PM
  #15815
heavyjeffd's Avatar
I'm running the triple garodisc/basket thing.
I'll just leave it where it is.
heavyjeffd is offline
Old 01-25-2012 | 09:37 PM
  #15816
Oh. then you can loosen it up! You're not stock like Craig's sayin'
Old 01-25-2012 | 09:38 PM
  #15817
heavyjeffd's Avatar
Well, I only have one thread showing, so I don't have a whole lot of room to go, lol.
First race with it is this weekend, hasn't seen a track yet.
Old 01-25-2012 | 09:39 PM
  #15818
Flush it up and run.
Old 01-25-2012 | 09:42 PM
  #15819
heavyjeffd's Avatar
Flush? Crikey.
Alrighty then. If it falls off I firmly blame you.
Old 01-25-2012 | 09:49 PM
  #15820
thebizz's Avatar
[QUOTE=F_ME;10227644]I measured the front width with stock wheels/tires at 288mm. ROAR legal width is 297mm. The JC Hazard wheels have a 3mm offset and widen the extremely narrow stance of the SC10 4x4. I understand the Blitz wheels have a 4.5mm offset and will fit the SC10 4x4. Anyone running these and how do you like them?[/QUOT
Jconcepts hazard wheels are 3mm wider per side which gives you a total of 6mm. hazard wheels have the widest offset to my knowledge.
thebizz is offline
  #15821
Cameron Kellogg's Avatar
Run one garodisc on the outside. You can leave the basket there just take out the extra disc and center slipper plate. Think of the clutch basket as a heat sink for the slipper now.
You will have more than enough bite with one garodisc and have more adjustment threads on the shaft.
Cameron Kellogg is offline
Old 01-25-2012 | 09:59 PM
  #15822
CraigMBA's Avatar
Wow that's brass, he's a factory driver!
CraigMBA is offline
Old 01-25-2012 | 10:00 PM
  #15823
heavyjeffd's Avatar
I think he was playin'.
I drove enough 2wd mod buggy that throttle control isn't a problem.
Old 01-25-2012 | 10:01 PM
  #15824
Old 01-25-2012 | 10:33 PM
  #15825
Originally Posted by F_ME
Roylo,
My truck is new.
When testing on the street with too much brake the belt would skip.
Turning down the brake power to just below where the belt would skip solved the belt skipping issue and still gave me excellen braking as I previously stated. I have come up short on a quad at my track multiple times, stabbed the nose, and have not had the belt come off. None the less, I bought a chassis brace to keep the belt slack in check.
If you are having issues with your belt coming off after adjusting your brake power, I suggest again that you have something wrong with your truck. Maybe something is bent, out of alingment, or your belt tension pulley bearing is wasted. Just some ideas but what you describe is not normal. I have never experienced any issues with the belt coming off even under severe nose stabs at full race speeds.
Thanks for the ideas to check. That is another solution to turn down the EPA on the brakes. But I prefer to have full braking power. The brakes on my RTR dont lock on pavement or grippy surface even on full. It just pulls up pretty fast.
roylo is offline
