OFNA Nexx 10sc Thread
#796
Does anyone have a good setup for a high bite smooth clay track? I know the best tires are barcodes at the track. I was running the hyper 10sc. and just ordered the nexx 10 sc.
#797
bump.
#798
try supersoft - aka rebar or wishbone
#799
Whos buying all the 8mm pivot balls???? All the sites ive been to have them backordered
Can anyone recommend a substitute for them
#800
I hope they get the pivot balls in stock soon.
#801
Guest
i just had to get some pivot balls and knuckles for mine and they were hard to find! got the pivot balls off amazon actually, maybe try there. it wasnt the best price but i needed them. if your still hunting that might be worth a try
***** ok scratch that i just looked. Nitro house has the upper ones ofn39140, but the only lowers i could find(ofn40934) were twistedrc.com but they only showed 2 available! ************
#802
Guest
is anyone running a big bore shock on this truck? i tried a set of prolines but they wouldnt let the front of the chassis completely bottom out and i really didnt like that idea (didnt want all that on my front arms if it did bottom out the shocks). i keep having problems bottoming out with this truck and its breaking all kinds of stuff. thought maybe bigger shocks might help? anybody else have this problem?
#803
I run the shocks off the sc10 4x4 helps alot,but can still bottom out if you over shoot the jumps and land flat.
#804
I raced yesterday at thunder alley raceway. 4x4 scts had 30 entries, I was in the c main leading the race into a b main bump spot when another pillowball broke on me
#805
Most parts from Jammin SCRT10 fit Nexx10. I used Jammin aluminium strut towers on my Nexx10.
#806
Guest
I've broke several control arms, one pillow ball hub. Actually sheared the metal pillow ball off and broke the hub at the same time. Been having trouble now with servo arms stripping out and that's with a higher end hitec servo and aluminum arm. Jus got a steel arm ill see how that works. Also broke several bumpers but just switched to t bone bumpers and they are worth every penny! Work great!
#807
quick question, I was just wondering what 17mm adapters work well with the nexx10? I believe that any slash 4x4 ones will work, correct?
Have a heap of old buggy wheels and tires that I want to use.
#808
Anyone know if a 1515 2200kv CC motor will if without modifications?
#809
Just Picked up a Mamba Monster 2 and 1515-2200kv motor and 3ch spektrum receiver. Anyone have any recommendations on what pinion to run? I'm looking for speed, lots of speed.
#810
I tried a MMM and a 2650kv in mine with a 25 tooth pinion,2s battery and WOW it was insanely fast. No way could i race with it. But if you just want to go fast just gear it as high as you can. You can run up to a 6s with that 2200 though. I tried mine on the street with a 4s one time and I was just laughing at how fast it was. Looked like the tires were gonna fly off.
