#7621
Many shops should have the losb3568 in stock now and they will be fully caught up by the end of this week.
UPDATE...I double checked on diff pins today and getting them out...all of the CS pin people that called Losi shipped from Losi and those that called Horizon, they got most of them out today, some out on friday, and some out tomorrow.
I hope you got correct info.
#7622
#7623
my local hooby shop dosent carry losi. thats why i was looking for the size of the pins so i can match something up. and the closest one that sells losi is almost an hr away and there out of stock. im still on hold for horizon its been 57 mins. this is some shitty service. i doubt there is that many people calling or they need to exspand there tech department.
#7624
#7625
#7628
#7630
nope just the two from the center diff. i just got off the phone with horizon and they told me to call losi direct. i guess ill just take apart the front diff and try to match it up.
#7631
Salad you got me to go to the dark side I just picked up a Tekin 2650 and can't wait to feel the sensored difference, I got an amazing deal on it. I like my castle but the only issue I have is the "natural" drag on the motor the notchy feel when you spin the rotor in your hand. I think it makes it a bit harder to keep it from going nose down on jumps, also on very low traction surface can cause the wheels to actually lock up almost. I here the Tekin is nice and smooth. I know it's a lot of motor but I couldn't pass up a fresh motor from tekin for less than 50% of retail. I'll have to see what I like better Nue/Castle or Tekin 2650. I'm thinking Tekin but I will post my results asap, I have a temp gun on the way also to get some more accurate temp readings.
Salad I know your not a big MMP fan, but have you ever ran one in sensored mode? And if so any thing you can think of that I need to know, like settings vs. non-sensored motors?
#7632
LOSB0127 Differential Pins Request Form
I'm pretty sure it is but your post doesn't mention the form also,
because this is what I was told to do when I called Horizon, just checking.
#7633
i filled out the form like two weeks ago and gave them a call this morning, and they said mine will be shipped out this week. OH well still have my order for chris pins too
#7634
#7635
I tried the call back several times, once they called me back after 4 days the other times they never called me back.
good luck,
