#4711
Can anyone give me a good starting point with the silicone diff oil when I go to swap out the grease. I run on a small outdoor track which I would call semi rough. Certaintly not a groomed pro clay track. Lastest issue of RC Driver claims the manual say to use 10,000 weight in the front and center but I cant find that anywhere in the manual and they dont say anything about the rear diff.
#4713
Because we can.
#4715
#4716
I'm running the Havor Pro SC with the Ballistic 4.5t... I swithed the rotor to the 14mm one. Running a 13T pinion. Came off the track after a hard 6 min practice and the temps were around 120... Esc was 90... I was using a 2s 5000mah 35C pack...
Will see how it does after the races tonight!
Oh and i had to replace the trans cap module because it fried after the first battery pack i ran on it, when i got it!
#4717
What size track are you running on? I'm running the 4.5 stock right now with a 14T. I ordered the 14mm rotor and a 16T to try out.
Our track is ~100'x60', ~17-19 second lap times.
#4719
What he said... I have the same setup and put the 16 on it. Our laptimes run 29 and up. I hope to run it soon!!!!
#4720
Anyone know if these would fit the SCTE?
http://t-bone-racing.net/Short-Cours...0011-p428.html
They are tough bumpers.
#4721
#4724
I just hate that the bumper bolts from the bottom. Super sick/strong bumpers, just hate that it raises your bones and arms to achieve the same ride height.
