#4216
http://www.youtube.com/watch?v=F2r3pjlFWO0
#4217
Ya i still have steering, and doesnt re arm after it stops, its still on, here is a video, just watch my truck (silver losi)
#4218
If you have about 30 min, some patience and a couple of parts you can fix it.
Same thing happened here, I took a small metal picture hanger, a 1.5mm screw & nut, my drill w/ a 1/16" drill bit, some 30 min epoxy and a bit of heat shrink tubing and made it better than new.... It works Great..... check the pic.
#4220
#4221
Did you double check your programing ? I did have a Novak ESC that acted the same way before it quit working altogether .
#4223
Hmmm , kinda hard too say , cant hear if it cogs or stutters or anything . I'd say your battery is OK , could be a voltage cutoff issue but you ran for a long time after it cut out the first time and usually you only have a minute or less before you hit the hard cutoff and the car doesnt move anymore .
16
#4224
+ YouTube Video | |
#4225
Ok, that is your problem, I almost have the same setup except I run the MMP for esc. With 12T, I can almost run 9 minutes with the 5000 battery on a 1/8 track. I believe your battery is dumping. I think I posted this video before but, here is how big the track is again:
+ YouTube Video | |
but ill probably do a 15 or 14
#4228
#4229
I did a fix similar to that (but not quite as nice as yours) a few weeks ago when I broke a rear arm on my 810e in the same way. I did eventually find what must have been the last set of rear arms in the country. I now run a zip tie over the same area to the first X hole in the arm. I hope this keeps new arms from tearing out the same way.
#4230
mike truhe just won 4x4 sct awsome job losi!!
