#4052
I'm on my phone, so I can't see, but is RClive carrying the cactus classic all weekend? Is it on now?
#4053
#4054
#4058
Blitz hexes also make the truck wider. All you have to do is put a dab of red loctite on the pin and slide it in and a dab of red loctite on the axle before sliding the hex over the pin and the problem is solved. You have to let the loctite sit for about 30 min to an hour though. No need to get crazy with the loctite either. Just like with CA glue a little goes a long ways.
#4060
Just use a leather punch to make a nice clean hole. It's worth it and doesn't mess up the tire or anything.
#4063
Let me ask this: Regardless if I go with Tekin or Novak's BL 550 motor, should I go with the 4.5T for racing or the 5.5T one? Would the ESC's be able to tame down the hotter engine with proper gearing if I go with the 4.5T and keep low end torque high or? Since I am new to this class I want to make sure I have an engine I can control easily to start, but yet I want to make sure Im not losing races due to lack of engine performance. You thoughts?
Also, to my above questions, when going with a lower turn motor, do I increase heat/wear and tear on the ESC more even if I gear down vs. going with a less radical 5.5T engine that might be geared a little higher?
Anybody help me with the above questions?
ANybody?........Bueller?.......................... .........................Bueller?
#4064
Just got off the phone with Horizon. I was told diff pins were being sent to hobby shops, and since I bought my SCTE at a LHS, that I will need to get the pins from the same shop when they get them. Is that correct?
