Like Tree9Likes
Old 10-12-2012, 03:39 AM
  #40066
For those that have used a VW body does it last longer? With the tires being exposed there is less surface to crack.
SouthFloridaApp is offline
Old 10-12-2012, 04:18 AM
  #40067
Gene158's Avatar
Originally Posted by BmainStar
Cheater body!!
Normally I think those vw bodies look kinda lame but that one looks pretty sick all trimmed up like that.
Gene158 is offline
Old 10-12-2012, 06:04 AM
  #40068
Jake C6R's Avatar
Originally Posted by Pygmy
I took my SCTE to the track for the first time, and in 2 batteries time I lost 2 bodyclips.
What clips can I best use / how can I avoid losing bodyclips all the time ?
Another option is the Dubro body clip retainers. The come in whatever color you want. Just make sure you make the retainer hole the right size and they will stay put even after a good rollover.
http://www.ebay.com/itm/Du-Bro-Yello...item564c7cc1ac
Jake C6R is offline
Old 10-12-2012, 06:18 AM
  #40069
eddomak's Avatar
To be honest, I haven't used it much - really just when having a little fun off the track, so not through any rough and tumble or jumps. I still prefer my SC body. If I really do something drastic one day it would be to convert it to an 8ight-E.
I agree that I don't get it much, and I'm not a VW fan, but since it was free, and it makes me smile what a totally different attitude it brings to the same underpinnings. I certainly wouldn't have done it myself.
eddomak is offline
Old 10-12-2012, 06:42 AM
  #40070
stunter38's Avatar
Trader Rating: 73 (100%+)
Ok after 30 minutes of searching i just got the new tuning kit and wondering what blocks to put in frt and rear ?
stunter38 is offline
Old 10-12-2012, 06:57 AM
  #40071
Pygmy's Avatar
Just spotted this : http://www.competitionx.com/new-prod...-sc-baja-body/
Fits: Slash, Slash 4×4, XXX SCT, TEN SCTE, SC10, SC10 4×4, Ultima SC, Blitz
As the french say, quelle fuck ?
Pygmy is offline
Old 10-12-2012, 07:25 AM
  #40072
rcgod's Avatar
Trader Rating: 33 (100%+)
Zero blocks all around is same as stock. Most guys run +1 in the rear for 3 deg antisquat
rcgod is offline
Old 10-12-2012, 07:35 AM
  #40073
stunter38's Avatar
Old 10-12-2012, 09:21 AM
  #40074
wildracr29's Avatar
Trader Rating: 48 (100%+)
TCC, how do you like the Proline Ion's? I am going to run indoor clay and was thinking about this tire choice. Guess I could run suburbs, barcodes or rattlers (all look the same anyway lol) or pressure points. Just wanted a report on your opinion on one of the newer high grip clay tires. Thanks
wildracr29 is offline
Old 10-12-2012, 09:51 AM
  #40075
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
I've looked back several pages, and search is not turning up what I want to find. So far I bought a new sct ten, odered tekin 4000kv pro 4, rx8, 7954 hi-tech servo, (still waiting on electronics) and put on rpm a arms and bumpers, changed diff grease to oil and bought a 8 body to use as an overtray.
Stock towers and shocks don't look to impressive, and I want to use 8th shocks, and prefer to stick with losi. I'm just building this for fun. Can someone tell me (as if I were a newb) exactly what to buy to properly convert this to run 8th shocks and tower's.
Budget is not an issue, I just want to do it right, and once.
OG RC 10T is offline
Old 10-12-2012, 09:52 AM
  #40076
OG RC 10T's Avatar
Those vw bodies are bad a$$!
Old 10-12-2012, 09:56 AM
  #40077
What is part numberfor set screws what holds suspension hingepin b4109 ?
Bigbearfin is offline
Old 10-12-2012, 11:05 AM
  #40078
buchanan88's Avatar
I have the Stock RtR and the steering servo developed a lot of slop, so i changed it out to a savox 1256 out of my d8 and now the servo goes crazy when you try to move it. Ive tried two savox servos and they both do the same thing, Put the old on back in and it works flawless but still obviously has the slop. Anyone had this issue? Why would would one servo be twitchy and cut out and the stock wont?
buchanan88 is offline
Old 10-12-2012, 11:33 AM
  #40079
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
it's a combination of things:
1) the savox servo draws more power than the stock servo
2) the internal BEC of the esc is weak and can't handle the additional amp draw
3) the spektrum receiver is very sensitive to power sag and will brown out much easier than other brands.
so the solution is to try a glitch buster capacitor like this one:
http://www.amainhobbies.com/product_...iver-Capacitor
that may eliminate the issue, or get an external BEC like this one:
http://www.amainhobbies.com/product_...Adjustable-BEC
that should definitely eliminate the problem.
RC*PHREAK is offline
Old 10-12-2012, 12:02 PM
  #40080
rcgod's Avatar
I would go straight to the external bec. A cap will just be a band aid. And the cap might work for a while but if the bec gets any weaker over time it will start acting up again. Save time and money and get the bec. You will probably need it down the road anyways with that esc.
rcgod is offline
