#3482
As Salad said, Losi has known about this pin problem
For months now. The thing is Losi fixed the problem before the SCTE was released. The screw up was over seas. Losi had the problem pegged and had the fix for it. It's just unfortunate that the pins were not built to the new Losi specs.
http://www.rctech.net/forum/8523746-post1250.html
#3483
You need to call Horizon.
#3484
#3485
#3486
#3487
if you could i would like to buy some diff pins to pm me price please and thanks
#3488
specs
Just took my caliper to the stock pins. The specs posted by the other guy are correct.
and those titanium pins i told you about? There perfect!! Theres enough in one kit to do exsactly 6 losi diffs with solid titanium pins.
Will let you know how much machining is going to run to get the notch in them. If its high i will do it myself.
#3489
I think Ryan didn't know... He was told the hardened pins where put in the trucks. I believe Ryan, but I think there is a mix up on the other side of the pond.
Not sure why it would take 3 months to get pins. I don't believe it will take that long. If it does, there is a serious issue in their process and I smell re-org lol.
#3490
#3491
#3492
oh i found mine so we're good to go!
#3493
