Well today was a absolute nightmare, i switched the pinion and after setting the mesh and tightening down the screw with very little force the screw stripped. Ive set my mesh many times and alot of wrenching in the past but have never seen anything happen to a screw like this. So now i am stumped, i have a rounded off screw and i cant set my mesh if i switch pinions. Someone mentioned to me that i could cut a slot in the screw and use a screwdriver to get it out, is there ANY other way? It is driving me nuts i cant stand to look at it! And there is NO WAY i will be leaving it like that.
These are my favorite hex's but Losi make some other set too.
http://www.horizonhobby.com/products...-set-LOSA99104
For those who have purchased and installed, do you see a noticeable difference? I race about every other week in an indoor track...thanks for your response.
Team Losi Racing Tuning Kit (TEN-SCTE)
Includes:
Rear Shock Tower, Carbon, 4mm
Front Shock Tower, Carbon, 4mm
Rear Hubs, Aluminum
Shock Tops, Aluminum
One Piece Shock Standoffs
Shock Collars, Aluminum
Adjustable Front Hinge Pin Holder Set
Adjustable Rear Hinge Pin Holder Set
Includes:
Rear Hubs, Aluminum
My buddy ran his truck for the first time today and after the 2nd battery we noticed that his rear center drive shaft was bent, I checked mines and it had a very slight bend also but barely noticeable, has anybody experienced this before and is there an improved/upgraded replacement part?
Broke the steering bell piece tonight
Broke it off tonight. I was asked if I had set the steering limits, and I said no. I have the Hitech 7955TG so it's got lots of power. I probably had just been lucky it didnt break all these 50+ packs i've ran. I am going to get it replace and then set the limit if i turn L then R to be just a hair at under the max, right?
What about running aluminum ones?
My trucks in the garage, but I believe it was the piece in the bottom that broke. it's the top portion of that combo and it broke right where it connects to the linkage that ultimately connects to the servo horn/arm.
[QUOTE=AgroAMG;10199482]Broke it off tonight. I was asked if I had set the steering limits, and I said no. I have the Hitech 7955TG so it's got lots of power. I probably had just been lucky it didnt break all these 50+ packs i've ran. I am going to get it replace and then set the limit if i turn L then R to be just a hair at under the max, right?
IMO there is no need to run aluminum ones. This is my 3rd 8ight based vehicle and I have never broken those parts. If you don't set your travel your asking for trouble. Spend a few bucks and get replacements, then set your travel/end points and see how it goes.
Everything else is easy. The little shims that people talk about are located between the little square pin holders and the planetary gears and they're REALLY little and like to stick to things and get lost. Just pay attention to those and you'll be fine.
You don't need anything but diff oil, some type of sticky grease, and some type of cleaning agent to clean out the old grease (I like nitro clean that you can get at a hobby shop).
I just did it for the first time a few days ago. I think the only trick is to find the right screws to remove for the front end to come off. I actually found this video useful: http://www.youtube.com/watch?v=N4e0DVMgYZQ Although it's not very well done (and some it's some kid doing it). Just watch it till you see how to take off the front end to access the front diff.
Aluminum-Rear-Chassis-Brace
Quick question: is this the rear chassis brace you are using?
If so, is this a direct fit?
Thx for your feedback.
Best,
V
Registered User
That kid is probably one of the best drivers out here in so cal... I believe he only has 2 sponsers boca bearings and thunder power...He should have more I was watching him in a race against Frank Root and they were basically battling the whole race, this kid hauls F$&@!?& @55
http://www.bocabearings.com/productd...SubGroupID=153
Worth a try before you start grinding.
I'm going to buy a new set of rim's and tire's for this coming spring but I've only owned 2 different type of tire's before just got back into the hobby this year so I'm not sure what type would be good. I've owned the Proline Gladiators and Calibar's for my stadium truck.
The track I race on has alot of loose top to it and with the calibars they load up with dirt and are packed solid so those are out of the question and the Gladiators kinda of did the same thing.
So with that being said what's a good tire for a loose top soil that wont pack into the tread's???
(The stock Losi' SCTE tire's dont load up but I want something different) I think there was some sort of AKA brand tire I saw that looked like it may work and other people were running but I can't remmber the name.
That's awesome I'm going to pick up one before spring if everyone else doesn't buy them out
