i too noticed this , the arms needed reaming or if your a stickler then replacing.only one half of the holes as they twisted a lil. the holes tend to not line up properly on the a arms.
there should be no binding in the stock chassis. 30 minutes of run time should break in the truck. Sounds like to me you have a ESC setup problem or a diff shimmed too tight.
Sometimes on dusty tracks, dust can make its way into the hinge pins, then things bind up a bit...ream it out so its free.
Im in serious need of a rear diff housing! Who has them in stock?
What would the effect/tradeoffs be for going from 5K center fluid to 7K on a high-bite indoor clay track?
I'm wanting more "go" coming out of corners that go onto straights. I don't think the issue is power as I've got a RX8/4600 combo and good batteries. I thought that bumping up to 7K in the center diff might give more acceleration? Or any other ideas? Thanks.
Here you go !
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
http://www.amainhobbies.com/product_...Hardware-Ten-T
have you tried ebay. There are tons of parts on there
They have that as well !
https://www.ssl-stormerhobbies.com/c...ns&pn=LOSB3542
speed controls
What Novak speedcontrol will work in this truck???. And will rear xxx sct wheels fit the truck in the front an rear??
Anyone???????
Anyone???????
I dont know why when I had my SCTE and with the stock chassis it wanted to nose dive sometimes, then I put the carbon fiber chassis and it completly killed the problem and now it flies straight?
