Be careful with this one, the DE Racing SC10 4x4 wheels do not work properly on the SCTE, the ribs in the wheels are bigger on the SC10 4x4 and they hit the lower front arms on the SCTE and you can't use the full steering range unless you modify the inside of the wheel.
I have both cars and thought they would fit, should have bought the SCTE first as the SCTE wheels fit fine on the SC10 4x4
You didn't have to sink to his level , you may have even one upped him,, if that is what you were after
Of course Losi drivers are going to recommend the Losi.
i've driven both...i prefer the SCTE and I'll tell you why.
1) the SCTE is .75 lbs heavier. This has its drawbacks (battery runtime) but...in this class bumping is common. When people bump into the SCTE, they bounce off. The truck stays put. the weight also helps with the parachuting associated with short course trucks.
2) the center of gravity is lower on the SCTE, it can take turns better for me. not saying others can't control the torque rolls in the SC10 4x4, but i had issues with it.
3) the battery tray....good luck getting anything bigger than a 5000mah 2S into the batter tray on the SC10. What a pain in the butt that thing is.
im no Losi fan boy. My 2wd is an SC10
come on that was kinda funny
On the track, read the above. Other 4WDs bounce off of you. They're in the way? Shove them aside if they're lapped traffic and won't let you pass.
Note that all my other vehicles are AE. I wanted the SC10 4WD initially, but then I did some research and ended up with a Losi.
How are the stock tires on outdoor dry clay?
I am the project manager for this truck. The stock tires will be just ok on outdoor dry clay. Something really to just run the truck with until you get to the track and find out what tires they are using for racing and pick soem of those up.
I found the stock tires to be pretty dang good for all around/practice. Have you seen what the sc10 comes with..... Why do they even bother.
