That's it so far. I was a little disappointed by this.
The ourselves are also showing a lot of wear after 8 or so runs.
I had the drive shaft pin (pin that the outdrive powers to turn the drive shaft) on the right rear drive shaft push out from the end of the drive shaft. It ended up chewing through the surrounding portion of the rear tranny case. I hammered it back in and ran it again without issues.
So, let me get this straight - you're no longer NitroAl - but rather..... uhhhh... lessee..... VoltageAL??? SCTEAl??? hmmmm. have to give this some thought but obviously a NAME CHANGE could be in order!!!!!1
Congratulations Al - you work hard on your stuff and you work hard on the track - a more deserving winner would be hard to find!
You can get the 5mm 1410 upgrade rotor right now.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBLCG&P=7
Go to the Losi site and they have the set-ups listed there. The truck comes with black medium springs. The new spring sets are due in a few weeks.
Hey Turk you can contact horizon hobby and use the call back feature and they will call you back,then tell them your problem and they WILL send you new ones!!There is no history of Losi or HH not replacing parts for these trucks when parts are not performing on a new or near new truck!
