TLR 22 Racing Buggy Thread
I still think that a loose slipper, at least for a while, is key to a good, long lasting diff.
As for the diff, I'm a complete noob when it comes to ball diffs and I built mine with all stock parts. So far so good, but I've only run the car a couple times yet. Time will tell, but so far I don't see any issues. One thing I did do was put a drop of CA glue on the nut before pressing it into the holder.
my new diff lasted for five feet. it was not the diff it was my set up it was loose from me.
I've heard of guys sanding the diff rights to make sure they are flat, what grit sand paper are you using if you're doing this?
Hi guys,
iīve just finished my 22 and have a question about the diff. Because its my first ball diff and i donīt know how to handle it right.
When i turn one wheel slowly i can feel very little bumps in my diff. The diff isnīt broke in. Are these bumps normal and go away when in brake in my diff?
Regards Chris
Regards Chris
400 then 600. Usually takes just a couple minutes with medium pressure. I use a little shock oil on the sand paper as well. More of a wet sanding that way.
R/C Tech Elite Member
Hi guys,
Regards Chris
Regards Chris
Iīve tighten it until i canīt turn the outdrivers with my hand. It is definately not too tight. May be itīs because i havenīt sanded the diff rings?
If you tighten it all the way down without a break in process, you can flat spot your diff balls and ruin them before you get to run.
My diff stays tight and is smooth as silk, no need for any "b fast" crap
You don't need to sand the rings when they are new. In fact, the rings that come with the 22 are some of the best I've seen come in a kit. They come perfectly cross hatched already. Just need to be sure to use carbide balls and version two diff screw and nut (or Asscociated screw/nut) and your all set.
Hi guys,
Regards Chris
Regards Chris
It was my understanding the nuts would be a running change. Maybe old stock was still around Not sure when the diff nut was cut in for the kits or maybe it is just available as an option part.
http://www.horizonhobby.com/Products...ProdID=TLR2946
I thought they were replacing them in the kits though. Being just a team driver I may have been mistaken on my info. Hopefully Frank can help clear that up.
